Is it possible to put a DVD onto a flash drive?
Results 1 to 16 of 16
Thread: DVD on USB flash drive
why not? your typical dvd is over 4 gb so you'll need a large one, but dvd's are only composed of files that can be stored on anything, as long as the encryption is removed.
Flash drives almost all use the FAT32 file system so your file size is limited to 4GB, which means putting a DVD ISO is usually not possible, but you can certainly put the video_ts folder on a flash drive so long as no single file is more than 4 GB. Windows Vista supports a modified version of FAT32 for external drives that supports files larger than 4GB but that file system is only supported by Vista.
Yes you can store a DVD on a flash drive. I know of nothing that will play it as a DVD.
At best, you can play the individual vob files.
DVD VOBs are all 1 GB or less, so they can be copied onto FAT32, NTFS, etc.Originally Posted by festmaster
The question is, what do you do with it?
You can certainly play a VIDEO_TS folder on a PC, regardless of file system.
(E.g., with VLC, MPC.)
Stand-alone players, who knows, it's not a standard feature.
festmaster
Flash drives can be reformated as NTFS if they are large enough. Well I think they can. I have reformed FAT16 drives to FAT32. At 1GB Windows XP wouldn't allow NTFS. It sure cut down on the space wasted on slack due to the large number of small files I had on the drives.Flash drives almost all use the FAT32 file system so your file size is limited to 4GB,
Megahurts
VLC should have no problems playing the whole DVD on a flash drive. It will even play an ISO. Of course that will take at least a 8GB drive for most DVDs. And maybe a reformat to NTFS.At best, you can play the individual vob files.
The Western Digital media player referenced hereOriginally Posted by Megahurts
http://forum.videohelp.com/topic358929.html
will play it and it supports NTFS on flash drives with no problem.
The assumption is the USB drive and cable can keep up
with the computer app.
A DVD in an internal DVD drive may have faster throughput
than one on a USB drive.
Originally a member since 2001, LONG LIVE TARAN's!!!
I suggest reformatting your flash drive to NTFS; more storage, more stable file system, no 4gig file size limit.
So buy one for the things that need Fat32 and have another for NTFS. Linux reads NTFS these days. So does the Mac.And less compatibility.
Didn't anyone besides me notice that this thread was 2 YEARS old? 2 years ago it made more sense to stick with FAT32 for all flash drives.
Ethelred
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / HDTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Help formating a promotional usb flash drive
By freebird73717 in forum ComputerReplies: 17Last Post: 18th Nov 2010, 06:53 -
USB flash drive/.avi files
By joecass in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2009, 07:41 -
Soundboard that records to USB flash drive?
By Try4ce in forum AudioReplies: 3Last Post: 14th May 2007, 13:52
