Results 1 to 10 of 10
    Hey all
    Whilst looking at the start up programmes on my computer, I noticed this. Can anyone tell me what this start up is ?
    Thanks in advance.
    Looks suspicious. I would run anti-virus scan on that folder, and disable that for startup
    Check taskmanager to see if any suspicious processes are running.
    Likely a virus or other crapware.
    I checked the process, nothing to be found suspicious of. I did however remove a few viruses few days ago. Not sure if that would have been traces left behind ?
    My Anti virus didn't pick it up now, after scanning the folder, but have now disabled it on start up.
  5. Member Xylob the Destroyer's Avatar
    Nice!
    I particularly like this one shown here
    I have 2 of them like this...
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  6. Member isogonic's Avatar
    you should be suspicious of anything running out of a temp. dir
    most likely a left over entry from malware
  7. Member Xylob the Destroyer's Avatar
    close all programs.
    click start > run
    type %temp% and hit enter
    delete everything you can
    Thanks, I did that, only a few files couldn't be deleted. I did a scan in safe mode using Spybot and found a registry key 'sexvid' goodness knows where that came from.
  9. Member Xylob the Destroyer's Avatar
    Originally Posted by DuBsTaR
    ...found a registry key 'sexvid' goodness knows where that came from.
    sure...
  10. Member wtsinnc's Avatar
    sure...
    I wish you had sent it to me for analysis.
    THREADKILLER !
    References on File.
