I have six Hi 8 tapes which I captured to HD via a Sony Digital 8 camera.
The DV captures all have similar technical specs ..which as Media Info shows is
follows:
General
Complete name : I:\CAPTURE\Tape1\TAPE1.avi
Format : AVI
Format profile : OpenDML
File size : 19.7 GiB
Duration : 1h 33mn
Overall bit rate : 30.0 Mbps
Recorded date : 2065-25-45 46:26:25
Video
Format : Digital Video
Codec ID : dvsd
Codec ID/Hint : Sony
Duration : 1h 33mn
Bit rate : 28.8 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4/3
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Bits/(Pixel*Frame) : 2.778
Stream size : 18.9 GiB (96%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 1h 33mn
Bit rate mode : Constant
Bit rate : 1 024 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Resolution : 16 bits
Stream size : 687 MiB (3%)
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 40 ms
So I now need to output the onto DVD.
- I will have to edit the raw capture to remove some rough bits at the
beginning and ends...plus remove a few points during the tape where the camera
was stopped and started.
- Then I need to encode the Video part to MPEG2 using CCE via Avisynth.
- Convert the Audio to 48KHz and convert to AC3.
- Take the Video and Audio into DVDLab and add Chapter points and simple Menu
and output as DVD...then burn to DVD.
So I need some advice ...
What is a good and easy to use editor that I could do the cutting with??
(Similar to MPEG Video Wizard for MPEG2 editing)
ie do cuts on timeline and output the edited DVfile back as new DV file(ready to be encoded in CCE)
The audio needs obviously to have the sample rate changed to 48KHz.
Is there a tool that I could use to do this plus encode as AC3???
I know its asking a lot...
or do I have to do the resampling ...then output a WAVE file
then encode as AC3..ready for Authoring?? ie three separate tasks and tools
or should I be asking this Part in the Audio Forum??
Any advice appreciated...
Results 1 to 9 of 9
Thread: Captured now edit..advice
From reading an earlier post I realise now that using the Sony Digital 8 camera
has allowed the capture to convert to Sony DV for the video...
and then the audio is the originally captured 32KHz PCM audio.
So will I need to install Cedocida DV codec to allow me to edit the DV??
Is there a simple timeline based editor that I could do the editing of the DV video part?
(as mentioned similar to the very easy to use MPEG Video Wizard for MPEG2) -
I just tried using AviDemux to do simple editing...remove bits at beginning and end
and then output a copy..ie unchanged format
It split the output into 4 gb chunks...what the heck?(original was around 20Gb)
Does AviDemux operate as though its in FAT32 land?
Any ideas? -
Yeah ..thanks poisondeathray!...I just found that out myself as well!!
Can nothing be straightforward...
See how this goes now... -
ticking that open dml setting box did the trick!!
nice big fat 20Gb avi...now to edit the five other DV captures -
Yes I've used it before; the audio from aften is good
It uses ffmpeg for the MPEG2 engine, which is fairly good. Personally I think CCE and HCenc maybe slightly better in terms of quality. You can test it out on some short samples to see for yourself
In terms of speed, HCenc scales better with more cores and is faster.
If you are happy with CCE and now have an edited DV-AVI to input then go you're all set!
Edit out material from dvd's/Need advice please
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2010, 18:15 -
How to split and edit captured video
By perinet in forum Video StreamingReplies: 0Last Post: 22nd Nov 2009, 09:40 -
How to edit/Remove Commercials from .ts files captured by ProgDVB?
By MounaLafi in forum DVB / HDTVReplies: 4Last Post: 2nd Oct 2009, 06:41 -
How to edit videos captured via TV card?
By cristolin in forum DVB / HDTVReplies: 3Last Post: 24th Feb 2008, 14:32 -
How to edit captured stream ?
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2008, 11:52
