I have a HD raw 264 video stream from a blu-ray rip that I'd like to mux to a MP4 format, I have converted the AC3 to AAC mp4.
I can play the raw 264 stream via VLC, or PowerDVD.
When I mux it with the audio to a mp4 format with YAMB, MP4box, the resulting files does not play properly I can hear the audio but the picture is all messed up, just strips of artifacts and colour..
has anyone any ideas why ? I have heard something about key frames.. what is this ?
Thanks in advance..
Mark
Post all the details from the h264 stream and mp4 stream after muxed. Use MediaInfo.
Thanks, I'll do this later when I get home
Hi there, O.k heres the output I have
eneral
Complete name : D:\Video.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 19.2 GiB
Duration : 1h 56mn
Overall bit rate : 23.5 Mbps
Encoded date : UTC 2008-11-16 01:00:43
Tagged date : UTC 2008-11-16 01:00:43
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Duration : 1h 56mn
Bit rate mode : Variable
Bit rate : 23.2 Mbps
Maximum bit rate : 52.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.466
Stream size : 18.9 GiB (98%)
Tagged date : UTC 2008-11-16 01:55:22
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 56mn
Bit rate : 350 Kbps
Maximum bit rate : 448 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 292 MiB (1%)
Encoded date : UTC 2008-11-16 01:54:20
Does this help at all ?
Yeah,
O.K so I tried MP4muxer with simlar results... really confusing me as both streams seem to be playable before muxing into MP4 container...
Something is very strange....
Somehow things are corrupting when muxing, if I play the resulting file sometime I will get the odd frame were I can see part of the picture otherwise it's just loads of blocks..
Did you specify frame rate when muxing? What happens when you mux video alone (without audio)?
Also check if other containers have this problem, this may provide more information:
e.g. use mkvmergegui to put into an .mkv container
e.g. use tsmuxer to put into .m2ts or .ts
hi yes i'm specifying 23.976..
I have muxed the video into a mkv file and this works..
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
Encoding SD video with H.264 to be 100% Blu-ray compliant.
By PuzZLeR in forum User guidesReplies: 10Last Post: 12th Oct 2011, 20:28 -
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 2Last Post: 27th May 2011, 16:06 -
Blu-Ray to Mp4 x.264 1080p won't play on PS3
By Patrick_H in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Dec 2010, 10:53
