I am using Windows Vista SP1 and Sims 2 (4CD) game. I am installing the backup copy of the game as my original is broken. It is a full backup and installs well, however, when trying to run it, I get messages such as "insert disc 1 into disc drive" and when looking for a solution, you need to download an updater which I did, I inserted disc 4 as requested, but still no luck, it keeps asking for disc 4 but nothing keeps happening. I heard there are patches and cracks but I don't know where to look and which ones to use, can anybody help?
gamecopyworld used to be a good place to look for such things......... usually a nocd "patch" is required.
Copies often don't have the CD check files/system. So although the game will install, it will never play.
Google is your Friend
Thank You, works perfectly, I used that site before, but I never did find it again.Originally Posted by aedipuss
Other things to try, of course, would be running the game as admin, or editing the shortcut's properties and telling it to run in XP compatibility mode.
Perhaps EA/Maxis have a patch you can download, if they have a website for the game. Or a forum where you can ask about it.
(BTW, is the game being discontinued, or something? I want to get it (Double Deluxe, at least) just for fun, but Wal-Mart's suddenly marked all the Sims 2 titles down by half, or more, and it's almost impossible to find, there. So, I'm just curious.)If cameras add ten pounds, why would people want to eat them?
Those were the first things I tried, it didn't work because I am using a backup copy of the game instead of the original.
As for the game, I don't think its discontinued, its one of the most popular PC games ever.
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Canopos ADVC100 doesn't work with Vista 64?
By something random in forum CapturingReplies: 4Last Post: 23rd Oct 2009, 18:33 -
Windows Vista XP 64 bit Oh, my. Printer doesn't work!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2009, 23:27 -
MSADPCM doesn't work with Vista Home 32 bit
By programm in forum Video ConversionReplies: 1Last Post: 6th Mar 2009, 10:48 -
Doesn't work with Vista SP1
By hordak in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 14th Mar 2008, 15:19
