I recoded my DV to the DVD format and realize the files are over 4.7GB. I hope not to lost any quality. Is it possible to fit the whole thing to a SL DVD-R?
Results 1 to 14 of 14
Not without re-encoding or trimming some video off the ends.
A DVD-5 actually holds about 4.37GB. You could use a Verbatim DL+ disc if you don't want to re-encode.
What program did you use to encode/author with?
If you've already authored your project, you could try DVD Shrink and see if the results are acceptable.
Can a person with a 46" waist fit into 36" waistline pants?
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
I use Windows Movie Maker to capture DV, Tmpgnc DVD Author to author.Originally Posted by redwudz
Thanks. I will try DVD Shrink.Originally Posted by Epicurus8a
Spandex, LS, spandex. It ain't pretty, tho. Try to use black spandex, it's a bit more slimming.Originally Posted by lordsmurf
What are you converting it to mpg2 with ??
If you use a good encoder you can set the bitrate and have it the right size the first time.
Re-encoding it or transcoding it a 2nd time will decrease the quality.
Small amounts are usually not real noticeable.
It's up to you if you think it is acceptable when it's done.Originally a member since 2001, LONG LIVE TARAN's!!!
What are you converting it to mpg2 with ?? It is TMPGnc Plus 2.5Originally Posted by Noahtuck
Use a bitrate calculator to work out the correct bitrate, encode using that bitrate, either as a Constant BitRate, or as the average for a Variable BitRate encoding, and the authored DVD will fit.
Use DVD Rebuilder ... works for me ... with the Cinema Craft Encoder SP v2.70.02.12 encoder ... I have the Pro version for a few years now when it only cost $10 .... I use to do 9 passes but everybody here says it is a waste ... so I use 4 Pass ... 5 Pass ... sometimes 6 Pass ... takes about 200 minutes to process a DVD Movie ... after I have used CloneDVD2 to trim out the fat.
All good, if your source is a DVD. if you are encoding from a DV source then you should get it right the first time, not waste time, effort and quality re-encoding it because you screwed it up.Originally Posted by lacywest
You write that as if you don't understand the question or like i should have known the answer when all you mentioned was windows crap maker and TDA 8)Originally Posted by better life
What guns1inger said.Originally a member since 2001, LONG LIVE TARAN's!!!
I got it to fit a 4.7GB, I am satisfy with the picture and sound quality since it shrinks only a tiny bit.
Thanks all for your advise.
I have a 4hr mpeg 2 video and i need to fit it into a 4gb dvd-r
By missyfy in forum Authoring (DVD)Replies: 4Last Post: 3rd Feb 2011, 04:12 -
I'm massively confused: Want to fit about 2 hours worth of video on a DVD
By karlcward in forum Video ConversionReplies: 2Last Post: 21st Oct 2010, 17:51 -
Video won't fit on dvd
By chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 07:50 -
Avi Video That will Fit a CD
By niteghost in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 09:21 -
Please explain this to me (lengths of video that an fit on a DVD media)
By perfection in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2008, 18:32
