I'm not sure if this is the proper place to post, but it's the closest that I could find relevance.
Anyhow, here's the deal... I have a standard CRT tv big one very heavy... but good picture stillPhillips Magnavox and using it for years with different DVD players.
Just recently I decided I wanted to play my AVI files on my DVD player rather than converting to VOBs etc all the time, very lengthy process, so I burned my AVIs on one disk and watched them on a player I had purchased, but it was missing some features that I wanted, so I returned it. Then I bought another player, so I disconnected the one I was using (with the tv turned on... not sure if this matters or not) and when I connected the new one and turned it to the channel before ch.2 to broadcast the signal, all i see is black. I then hooked the original player back up and same thing, black screen. My tv works fine on all other channels but I can't seem to get the dvd players to work now.
Any ideas?
sounds like you've got your wires mixed up
before ch 2?Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
@ zoobie
Well, that's what I thought at one point but I've checked them and they seem to be in the proper jacks. I'll do a bit more checking tomorrow when I have time to actually move the tv and see what happens. I'll repost my findings.
@ zoobie ...
Ok, I got it worked out. I can't count how many times I've connected components using rca cables in my life. I don't recollect that I ever had this much of a problem before. I thought it was the setting on the tv, so I went through some troubleshooting and afterwards when connecting the cables I literally stared at the components to make sure I wasn't doing anything out of the ordinary, also making sure that they were fitted properly.
So, I can rest assured that posting here definitely helped fix the problem!!
Thanks again for the very obvious suggestion which by all means I am very grateful for you taking the time!! Cheers.
@ Moderator/s problem solved, please close topic. Thanks!
anytime...
I've done it myself...especially when there's a mess of cables involved
any ideas of what the US black Friday deals for bluray players will be?
By yoda313 in forum Newbie / General discussionsReplies: 7Last Post: 20th Nov 2011, 17:04 -
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 17:27 -
multiAVCHD - subtitles no longer work
By bobo343 in forum Newbie / General discussionsReplies: 3Last Post: 8th Apr 2010, 08:58 -
SVCD2DVD used to work, no longer
By gddeluca in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 23rd Sep 2009, 10:45 -
Coby DVD7107 Help - The hack posted does not work!!! Any ideas?
By Catenkristen in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Jul 2008, 14:46
