    I have a zen Xfi 8Gb player.
    It accepts avi (divx or xvid) or wmv9 in 320x240 (176)
    Its a known fact that the Zen goes out of sync with avi files, wmv performs a lot better. Personally I don't care for wmv but I'm stuck with it. Having done tests with super and virtualdub to take avi files to 320x240 xvid or divX5 I get real sync issues. wmv does perform better in this case.
    I have converted one (CBR) tv series to wmv but most of the content I want to put on the Zen is avi with VBR audio, every single one of these seems to crash windows media encoder or video resize.
    Is there a good way to deal with VBR avi content to output a wmv9 file?
    I am using XP sp2 on a 1.7Mghz computer
  2. Member yoda313's Avatar
    I believe you mean you have a 1.7 GHZ computer
    Anyhow -
    Try something like SUPER to convert the avi files instead. It has a wmv output setting.
    Try Encode360
    Why not use the new version of Virtualdub which supports VBR MP3 and Direct Stream Copy the video and re-encode the audio to CBR MP3. This way you don't lose quality with the video and it's a lot faster than converting all those files to WMV.
    I tried encode 360 but it didn't like my computer and codecs....
    super does not do ( as far as I am aware) wmv9
    AVC works very well but its a little slow...
    it works tho, so problem solved.....
