hello all i recently downloaded some flv and mpeg files using real player,these play ok on my pc.
i used free trial of alone?? dvd movie maker to convert a flv file and mpeg file to dvd,
but find my sony hxd560 dvd recorder will not recognise the dvd i have burnt, also think firmware in sony is ancient and no upgrade avaliable.
a 40mb flv file when conveted takes up almost an entire dvd r disk???
some one suggested dvd flick but this does not seem to have a conveter funtion.
i wish to play flv and mpeg files using seperate dvd player and widescreen tv.
is it possible to convert dvds to a format where i can queeze more movies on a single dvd, i believe divx is the format????
but i do not think my sony recorder is divx compatable (i have a sony ps3 connected to tv not sure if that supports latest codecs)
thank you![]()
DVD Flick can CONVERT to DVD-Video, read http://www.dvd-guides.com/content/view/229/59/ . Another option would be ConvertXtoDVD.
And yes you can convert DVDs to AVI DivX to squeeze several movies/DVD, use AutoGK or FairUse Wizard. The ps3 should support divx.
whats the best software to convert flv to avi
By videodude1966 in forum Video ConversionReplies: 1Last Post: 10th Feb 2011, 03:16 -
Convert to FLV software options
By jscape2000 in forum MacReplies: 2Last Post: 10th Mar 2010, 12:53 -
Convert FLV To DIVX
By jonny68 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2008, 17:36 -
Convert to flv for youtube? What software?
By vid83 in forum Video StreamingReplies: 3Last Post: 18th Jun 2008, 07:24 -
Divx to FLV to MOV to FLV again, just for the sake of some effects?!
By ayyash in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2008, 20:19
Statistics
Newest guides
Latest tool updates
New media comments
