VideoHelp.com Forum
    I'm converting some dvd's to mkv using automkv.
    All goes well but I have some things I don't get to work or doesn't do like I think it should.
    I have selected the ifo and given a destination folder. I want automkv to rip the subs so I have selected the right sub. after selecting everything I place it in queue so I can batch convert several dvd's at night. When I click start queue the process start but another instance of automkv will be opened. Is this normal?
    The next morning when I check the process I see several dvd's are converted to mkv but no subtitle. When I follow the process for a while I see the sub being ripped and placed in the temp folder but after finishing the conversion the sub is gone.
    How come.
    I have a feeling when I choose spline36resize instead of standard simpleresize the conversion process takes much longer. Is this correct?
    I guess automkv adds switchable subtitles in the mkv container and you might have to enable the subtitle when you play. Or have you tried that?
    Yes I saw that later. This one solved.
    But is it normal in queue a second automkv instance will be opened after clicking start queue?
  4. But is it normal in queue a second automkv instance will be opened after clicking start queue?
    yes it's normal
    when queue starts automkv will launch itself with parameters.. just let it work
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
    yes it's normal
    BHH
    Ok thanks.
  1. Replies: 7
    Last Post: 13th Aug 2011, 15:19
  2. Hard-coding subs for mkv in automkv
    By overwatch in forum Subtitle
    Last Post: 16th Jan 2010, 09:03
  3. Replies: 1
    Last Post: 12th Apr 2009, 19:23
  4. Replies: 1
    Last Post: 1st Feb 2008, 03:10
  5. Automkv x.264 Questions.
    By kidcash in forum Video Conversion
    Last Post: 6th Nov 2007, 12:04
