hello all
I just bought a standalone sony divx dvd player which says it can play mpeg4 vids but when i insert my mp4 clips it can not recognize or play any of them ? do i need to convert my clips to mpeg4 ? how to do it ?
thanks
DVD players that can play DivX and Xvid generally only play videos in AVI or .divx form, and possibly MPEG-1 and MPEG-2. You'll most likely have to re-encode your video into an AVI with a DivX or Xvid video stream, and MP3 audio stream.
Also, it might be a good idea to make sure the .avi/.divx video(s) don't exceed any of the points in this post:
http://forum.videohelp.com/topic357003.htmlIf cameras add ten pounds, why would people want to eat them?
Insert?Originally Posted by forare
Are they on CD or DVD?
forare - I'd have to see the exact claim that Sony makes to know for sure, but I'm guessing that they are claiming to be able to play MPEG-4 video (ie. Divx/Xvid) and NOT that they are claiming to be able to play video in MP4 containers.
USB flash drive !!!Originally Posted by hech54
ok here is an example of my file (downloaded from youtube using keepvid.com)
is it much different from standard mpeg4?
General
Complete name : G:\Wafaa Sultan\34video.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 10.4 MiB
Duration : 4mn 32s
Overall bit rate : 321 Kbps
Encoded date : UTC 2008-08-12 12:37:20
Tagged date : UTC 2008-08-12 12:37:20
Video
Format : AVC
Format profile : Baseline@L1.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 4mn 32s
Bit rate mode : Variable
Bit rate : 196 Kbps
Maximum bit rate : 501 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4/3
Frame rate mode : Constant
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.102
Stream size : 6.36 MiB (61%)
Title : (C) 2007 Google Inc. v08.13.2007.
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 4mn 32s
Bit rate : 123 Kbps
Maximum bit rate : 252 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 3.99 MiB (38%)
YES!!!Originally Posted by forare
There's no way this is going to play. It uses VC-1 for video. Your player probably doesn't support AAC audio either (few DVD players do).
I stand by my original statement in my previous post. You would do well to pay attention to that.
Changing default dvd movie palyer in WinXP?
By Whoosh25 in forum Newbie / General discussionsReplies: 2Last Post: 9th May 2005, 18:19 -
dvd palyer and cdrs
By adamk in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2003, 18:50 -
BUSH DVD PALYER - VCD PLAYBACK PROBS
By datasorber in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Jan 2003, 15:11 -
What DVD palyer is right 4 me? :-?
By appleguru in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Nov 2002, 22:59 -
which dvd palyer to buy
By vh51505150 in forum Newbie / General discussionsReplies: 9Last Post: 11th Aug 2002, 14:20
