Ok, I am struggling with this so bad, I have tried usins many programs, and am looking all over for how to do this. Ive done it before, with another video (Shooter, which had a resolution of 720x352 (anamorph) aspect ratio 2.47:1). The only problem I had with that viedo, was that it cut off VERY LITTLE on both sides, but at least it had the black bars on top and bottom. Anyways, I am trying to convert some episodes of Storm Chasers, which have resolution of: 1280x720 with an FPS of: 23.976. I have converted it with multiple programs, but when I put it on my ipod, in stretches it to 4:3 aspect ratio, or whatever the ipod is. What can I do to convert these files to ipod format, so it doesnt cut off anything, or stretch anything? The files are .mkv format too. Thanks!
Thread: Widescreen MKV to iPod
So I think what I need is for the video to be in a letterboxed 4:3 format, so it fill fit my screen, and still maintain is widescreen goodness
Doesn't videora ipod converter fix this automatically? Or does it not support mkv sources?
Well, Ive tried videora ipod converter, it supports mkv, but none of the profile seem to make it 4:3 letterbox, cause when I got to put it on my ipod, it strecthes again. Is there a certain profile I am missing? I have the latest version.
Well, I looked through all the prfiles, and non seemed to work. I see you can make more profiles, but im nto sure how to make it 4:3 letterboxed, I think I need to do the padding, but im not sure how to do it.
Extracting subs from MKV for iPod
By nj473 in forum SubtitleReplies: 4Last Post: 2nd Feb 2010, 13:35 -
MKV to IPOD conversion error
By ganjasmoker in forum Video ConversionReplies: 6Last Post: 7th Nov 2009, 23:20 -
MKV to IPOD MP4
By bae il sub in forum Video ConversionReplies: 3Last Post: 10th Sep 2009, 10:32 -
.mkv format to ipod with subtitles
By zps in forum SubtitleReplies: 1Last Post: 1st Nov 2007, 02:59 -
iPOD Video: How to convert widescreen to fullscreen?
By maxim730 in forum DVD RippingReplies: 4Last Post: 5th Jun 2007, 09:07
