    Hi Borax,
    I want to put 2 lines of words into a single button of the main menu. I did it the way I want and saved it. After creating DVD it still shows only one long line of these words, and this line go off the screen size. Can you offer any idea?
    Thanks alot
  2. Hi volam,
    How?
    Usually you have to insert a line break with Ctrl+Return (or Shift+Return) in the Edit Button dialog.
    If you did it that way, please post (or send) the .gfd file or at least some screenies...
    How does it look in the menu preview?
  3. Member AlanHK's Avatar
    Probably you are seeing a soft line wrap in the text entry box.
    To make a hard break, as Borax says, use Ctrl+Return.
    Thanks so much. I got it done.
    Here is another problem. I use GFD for the first time to authorize a 7.26gb iso file for burning into dvd+r DL. I use IMGBURN to do the job and got this message "Optimal L1 data zone start LBA: not found! (VTS-01). This image has not been mastered correctly for burning into DL (OTP track path) disc. None of the cell meet the DVD-VIDEO specification criteria for a potential layer break position. Do you want to continue?" . Ofcourse I did not continue and get help.
  5. Sorry, I've never created a DL disk yet.
    ...a 7.26gb iso file
    How was this iso file created? With imgburn, or by GfD itself (with the create ISO function which uses mkisofs.exe)?
    Maybe mkisofs.exe is not suitable for DL disks. I would try to burn the VIDEO_TS folder directly with imgburn. Then imgburn can select the layer brake itself.
  6. Member AlanHK's Avatar
    In GfD, click "Create DVD" to make the file set, not "Burn DVD".
  1. GFD Software, How to customly put text in button
    By volam in forum Authoring (VCD/SVCD)
    Last Post: 11th Nov 2008, 09:53
  2. GFD Dev: Remember last submenu button?
    By spamiaint in forum Authoring (DVD)
    Last Post: 7th Jun 2008, 12:58
  3. GfD button highlights
    By bratpop in forum Authoring (DVD)
    Last Post: 3rd Jan 2008, 06:38
  4. Chapter button pop-up text description in GFD?
    By awesomer in forum Authoring (DVD)
    Last Post: 18th Nov 2007, 19:21
  5. GFD DVDauthor: Anyone have problems with button highlights?
    By Bullworth in forum Authoring (DVD)
    Last Post: 18th Dec 2005, 10:00
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
