Closed Thread
    I have been trying to convert a movie (madagascar) that was ripped in mp4 format to ISO... but every time it gets to the audio encode part, it hangs and eventually errors out. I have been able to do other formats using this program, but not this one... here is the error log:
    code]
    DVD Flick error log
    Version 1.3.0.4 build 726
    Windows 6.0 build 6000
    *** Project info
    EncodeProf 2
    Threads 2
    OverScan 0, 3
    TargetRate 0
    TargetFormat 1
    TargetSize 4
    CreateISO 1
    CustRate 0
    EnableBurn 0
    EraseRW 1
    HalfRes 0
    LoopPlayb 1
    AutoPlayMenu 1
    MenuEnable 0
    MenuTemplt Mosaic
    VolumeMod 100
    WhenPlayed 0
    *** Warnings given
    *** Titles
    0 - Madagascar
    ChaptCount -1
    ChaptInt -1
    ChaptSource 1
    TargetAR 1
    ThumbIndex 515
    *** Project sources
    Madagascar 2005 H264 DVDRip 5.1 Madagascar.mp4
    Stream 0 (2)
    Dur 5154.83
    StartT 0
    Compr h264
    BitR 0
    1280x720 23.976 FPS
    PAR 1
    SAR 1.777778
    Stream 1 (1)
    Dur 5154.83
    StartT 0
    Compr aac
    BitR 0
    Chnnls 6
    SRate 48000
    Delay 0
    *** dvdflick.log
    4:21:25 PM: DVD Flick 1.3.0.4 build 726
    4:21:25 PM: Calculating stream sizes...
    4:21:25 PM: Disc space used : 4319748 KB
    4:21:25 PM: Average bitrate : 6216 Kbit/s
    4:21:25 PM: Total duration : 1:25:54 hours
    4:21:25 PM: 1 title(s).
    4:21:25 PM: Using Normal encoding profile.
    4:21:25 PM: NTSC target format.
    4:21:25 PM: CPU: Intel(R) Core(TM)2 CPU 4400 @ 2.00GHz
    4:21:25 PM: Threadcount: 2
    4:21:25 PM: Encoding video...
    4:21:25 PM: Title 0, source 0
    4:21:25 PM: Source Madagascar.mp4
    4:21:25 PM: Properties : 1280x720, Widescreen (16:9), 23.976 FPS, h264, 5154.83 seconds
    4:21:25 PM: Target BitRate : 6216 Kbit\s
    4:21:25 PM: Re-encoding
    4:21:25 PM: Madagascar.mp4" -vcodec mpeg2video -s 720x480 -r 23.976 -g 14 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 6166k -maxrate 6166k -b 6166k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags lanczos+accurate_rnd -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 2 -fflags +genpts -strict very -f mpeg2video -shortest -map 0:0 "dvd\0.0.m2v"
    5:16:34 PM: Applying 2:3 pulldown
    5:16:34 PM: "Documents\dvd\0.0.m2v" "Documents\dvd\pulldown.m2v"
    5:27:34 PM: Combining video sources...
    5:27:34 PM: Concatenating video...
    5:27:34 PM: Encoding audio...
    5:27:34 PM: Title 0, track 0, source 0 of 0
    5:27:34 PM: Source : Madagascar 2005 H264 DVDRip 5.1 ch-SecretMyth\Madagascar.mp4
    5:27:34 PM: Properties : 6 channels, 48000 Hz, aac, 5154.83 seconds
    5:27:34 PM: Recompressing to 448 Kbit\s with 6 channel(s)
    5:27:34 PM: -i "Madagascar 2005 H264 DVDRip 5.1 ch-SecretMyth\Madagascar.mp4" -i dvd\0.0.m2v" -map 0:1:1:0 -acodec ac3 -ab 448k -ac 6 -ar 48000 -threads 2 -async 0 -shortest \dvd\0.0.0.ac3"
    9:04:39 PM: -1 from EncodeAudio: Audio encoding failed.
    *** ffmpeg_audio_title0_track0_source0.txt
    ing stream #0.1
    Error while decoding stream #0.1
    size= 0kB time=10000000000.00 bitrate= 0.0kbits/s
    video:0kB audio:0kB global headers:0kB muxing overhead nan%
    *** ffmpeg_video_title0_source0.txt
    752kB time=5150.60 bitrate=6165.9kbits/s
    frame=123516 fps= 37 q=2.0 size= 3877505kB time=5151.60 bitrate=6165.9kbits/s
    frame=123542 fps= 37 q=2.0 size= 3878321kB time=5152.69 bitrate=6165.9kbits/s
    frame=123568 fps= 37 q=2.0 size= 3879138kB time=5153.77 bitrate=6165.9kbits/s
    frame=123591 fps= 37 q=2.0 Lsize= 3879860kB time=5154.73 bitrate=6165.9kbits/s
    video:3879860kB audio:0kB global headers:0kB muxing overhead 0.000000%
    *** pulldown_title0.txt
    Current GOP = 9164 Current Frame = 123480
    Current GOP = 9165 Current Frame = 123481
    Current GOP = 9166 Current Frame = 123482
    Current GOP = 9167 Current Frame = 123496
    Current GOP = 9168 Current Frame = 123510
    Current GOP = 9169 Current Frame = 123524
    Current GOP = 9170 Current Frame = 123538
    Current GOP = 9171 Current Frame = 123552
    Current GOP = 9172 Current Frame = 123565
    Current GOP = 9173 Current Frame = 123579
    *** Project destination folder
    0.0.0.ac3 0
    0.0.m2v 3972956160
    dvdflick.log 2372
    errorlog.txt 6563
    ffmpeg_audio_title0_track0_source0.txt 8334181
    ffmpeg_video_title0_source0.txt 515905
    pulldown_title0.txt 403726
    *** Drives
    C - HP - 2
    FS NTFS
    AvailSpace 142131
    FreeSpace 142131
    TotalSize 296198
    D - Recovery - 2
    FS NTFS
    AvailSpace 1032
    FreeSpace 1032
    TotalSize 9044
    E - not ready
    F - not ready
    G - not ready
    H - not ready
    I - not ready
    [/code]
    Buy it on DVD instead.
