Hi,
I used Apex Video Converter to convert an AVI file to MPEG1, then burned it on a VCD, but when I played it back on my PC and on my DVD player, the movie (audio and video both) plays too fast.
According to GSpot, the original AVI movie has a frame rate of about 29 fps, and the output NTSC vcd movie's frame rate is the same. How come the playback is too fast? Is there anyway around the problem?
Thank you.
LWC
Does the mpg file(not vcd) play too fast also?
Try convert with something else, like the old free tmpgenc.
Baldrick's suggestion to use TMPGENC is a terrific one. The free version will handle MPEG-1/VCD files very well.
Quick Media Converter will also do a nice job of converting from one format to another. In "Easy Mode" it chooses parameters that generally work without modification. It's also free.
THanks again. Using TMPGENC to convert directly to mpeg from avi worked! I already had TMPGENC installed, but I never noticed I could convert from AVI.
But TMPGENC doesn't work on WMV right?
Sadly, that is right -- TMPGENC will not work with WMV files. However, Quick Media Converter will.Originally Posted by LWC
How can I speed up playback on converted PAL avi?
By Trigger1101 in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2006, 23:16 -
audio problem 10 seconds into playback with converted .avi
By GMan55 in forum Video ConversionReplies: 2Last Post: 8th Nov 2004, 16:19 -
MPG/VCD playback with PowerDVD is way too fast
By Limbic in forum Video ConversionReplies: 2Last Post: 24th Oct 2002, 16:58 -
VCD playback....ok most of the time...super fast sometimes
By wipeout in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2002, 04:21
