Hi guys,
long-time visitor to this forum (8 years plus), first-time poster!
I am developing a NON-COMMERICAL application for the purpose of allowing people to catalogue their collections of downloaded video clips and am looking for people to test the Alpha versions of the software:
It's a Windows only app (win XP+ though not fully tested on Vista): Here is an overview of the functionality from the (limited) documentation I have thus far put together:
VideoPhile II was created for the purpose of managing and organising your multimedia files. Its powerful feature-set lends itself as an ideal solution for cataloguing large collections of media content. Specifically, it is aimed at collections that traverse multile storage devices and where it is otherwise inherently difficult to locate a particular file in a collection.
Through its easy-to-use interface, it is possible to quickly and easily locate any file in your collection and play it back.
Features include:
• Support for user's default Media Player
• Auto-creation of Library, including thumbnail generation
• Support for advanced Tagging, using hierarchies, links and synonyms
• Ability to perform complex, compound searches in order to identify and locate files
• Ability to create and playback ‘highlight’ segments from your files
• Facilitates basic editing of files (through external applications, where installed)
• Caters for collections that traverse many, offline storage devices
• Ability to create and organise dynamic playlists
• Support for a Bluetooth HID profile in order to use the application more conveniently when in TV-Out mode.
• Ability to generate ‘Poster’ images of files (commonly used as previews by file uploaders)
• Facilitates identification of duplicate files
Videophile II is a Direct Show-based application and, hence, it can play-back any media type for which your system has the necessary filters installed. My recommendation, if you are not already using it, is to have ffdshow installed, together with the Haali Media Splitter to handle MPEG-2 and Matroska streams. You may wish to supplement this with either or both Real Alternative and Quicktime Alternative for, respectively, the Realmedia and Quicktime formats, although there is some doubt as to the legality of these filters.
It's pretty stable as is but there are probably lots of little bugs here and there that I have not chanced upon yet. If anybody is interested in helping to get this to a stable Beta version I'd really appreciate the input of some of the hardcore among you.
PM me, please, at this site and we'll talk about your possible involvement: If mutually agreeable, I'll grant you access to my forum at http://videophile.freeforums.org/
Results 1 to 1 of 1
Thread: New Multimedia Library
Reformatting My Picture Library
By fmagreed2 in forum ComputerReplies: 7Last Post: 3rd Feb 2011, 14:15 -
Saving iPod Library
By Jeikobu in forum Portable VideoReplies: 2Last Post: 18th Jun 2009, 16:56 -
Music Library Question
By wwaag in forum AudioReplies: 0Last Post: 23rd Aug 2007, 14:58 -
video library software?
By vobnovice in forum Software PlayingReplies: 0Last Post: 7th May 2007, 20:40
