VideoHelp.com Forum
    I stumbled onto Media Center Control, which i thought would have done the trick.. it didnt work.. the test program said it couldnt find ffdshow, which was installed..
    I also found registry hacks to allow the files to show up in the video library, which they now do, but attempts to play them state that the video cannot be played..
    I think that in conjunction with mymovies, i could probably jerry rig something,but this isnt practical.. as i have a lot of camcorder files that i havent finalized into bluray format, m2ts files, that i'd like to be able to view in media center..
    Also.. short of media center, is there a way to view these short of clicking one at a time, almost like queue an entire folder up somehow and hit forward as i want to move to the next one (IE: maybe media center or powerdvd, but somehow without doing manual creation of anything)..
    Check out my Editing thread post located here: http://www.avsforum.com/avs-vb/showt...2#post14322602
  2. Member yoda313's Avatar
    Are you using a media extender like a xbox 360? If so try streaming with tversity. You should have better flexibility with it.
    While i do have a 360, i'm actually switching to the PC screen in the other room now (bluray playback).. So this one doesnt really apply.. i'm speaking strictly from the pc (media center)..
    I did try tversity awhile back, but i didnt like it that much, ie: you couldnt skip forward and backward very easily.
    Can you play the m2ts with windows media player? It should work if you have ffdshow (and I think haali media splitter) installed.
    Yeah, media player is fine, just not Media Center.
  1. Play blu ray m2ts file in Vista media center
    By ultraman36 in forum Software Playing
    Last Post: 10th May 2009, 05:41
  2. Getting HD Cable in Vista Media Center
    By lexicant in forum Capturing
    Last Post: 29th Feb 2008, 09:57
  3. Vista Media Center & DVR-MS file playback is poor
    By iukini in forum Media Center PC / MediaCenters
    Last Post: 16th Dec 2007, 05:11
  4. vista media center remote
    By skierrob in forum Newbie / General discussions
    Last Post: 10th Dec 2007, 02:33
  5. Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
    By JBredensteiner in forum Media Center PC / MediaCenters
    Last Post: 14th Jul 2007, 01:33
