Hi Baldrick and others
Here's my problem...
I have ripped a BR movie to HDD using AnyDVD HD. So far so good.
Following your tutorial I run Ripbot264 (latest) and it begins to demux video and audio.
But then I get this message:
DirectShowSource: Couldn't open file J:\temp\Ripbot264temp\Job1\video.mkv.
An object or name was not found.
(J:\temp\Ripbot264temp\job1\GetInfo.avs line2)
Anyone else come across this message, and what can I do about it??
Thanks in advance
Zen
Results 1 to 10 of 10
Thread: Problems with Blu-ray to MP4 HD
Please POST in the blu-ray to forum.
Have you installed all required tools?
Exactly the same problem, all tools installed
Baldrick
Yes and Yes
Something like this happens on Vista frequently. If you are on Vista, it won't let you write to the directory unless you run as administrator and disable UAC
Baldrick
Yes and Yes for me too
poisondeathray
I am on Vista and run as administrator and have disabled UAC.
No go.
My other computer with XP same thing.
I am experiencing the exact same problem with Ripbot264 on my desktop running XP. Does anyone have a workaround for this problem?
Do unto others....with a vengeance!
Thanks for the help, I will attempt to do that tonight.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Trouble Converting Blu-ray to Mp4
By F.Garvin in forum Video ConversionReplies: 2Last Post: 26th Oct 2010, 22:45 -
Help With Blu ray to MP4
By mohawkcr in forum Blu-ray RippingReplies: 3Last Post: 11th Jul 2010, 17:47 -
Best blu-ray to MP4 software?
By David9799 in forum Blu-ray RippingReplies: 5Last Post: 15th Oct 2009, 12:37 -
Blu-ray to .avi - or .mp4?
By Loevgaard in forum Blu-ray RippingReplies: 1Last Post: 29th Aug 2009, 11:43
