Here's what I get from the Intel PC:
Quite a bit of difference.You can see the EPP setting in my setup. I basically duplicated them in BIOS.
A few shots of the new server:
Looks OK from the front. The door is closed most times in use.
Back view.
I did clean off the fingerprints.
The front panel open. I put in three of the Lian-Li 5.25 to 3.5 adapters. About $4 each. They have two small fans and a fan failure buzzer. Cheap, but work very well. I could have painted them black to look better, but it's a server.
The internals. The 500W Thermaltake PS is more than enough for 10 HDDs. I'll leave the PATA DVD ROM in there for now. Also presently using a 200GB Maxtor PATA boot drive. Two of the lower drives are the 500GB Seagate SATA drives. The upper next is a 80GB drive, but I have a another 500GB on order. The topmost drive is the Maxtor. This photo was taken before I added the SATA cables and the two PCI slot SATA controllers.
I stuffed the extra PS Molex connectors up on top of the PS until they are needed. I cut off the floppy PS connectors. I used a stock CPU cooler that I had and added a 120mm fan in front of the HDDs. It runs very quiet. So much so, that I'm going to retrofit the older servers with quiet fans.![]()
When I add more drives, I'll probably pull the PATA drives and replace everything with SATA as I have enough SATA connections with the two controllers added.
Results 1 to 1 of 1
Thread: GSkill F2-6400CL5D-2GBNQ ram
RAM not recognized
By videobread in forum ComputerReplies: 4Last Post: 27th Nov 2011, 11:34 -
Value ram
By jollyjohn in forum ComputerReplies: 19Last Post: 5th Mar 2011, 06:21 -
RAM!!
By HotDamn! in forum ComputerReplies: 14Last Post: 15th Dec 2009, 07:43 -
Installing RAM
By Nitro89 in forum ComputerReplies: 32Last Post: 5th Mar 2008, 11:27 -
more ram?
By Heywould3 in forum ComputerReplies: 7Last Post: 24th Jul 2007, 11:32
