VideoHelp.com Forum
    Hi all
    Just bought this camcorder along with a generic (non-sony) HDMI-to-mini-HDMI convertor. I connected the camcorder to my Panasonic 42" HD ready plasma via a HDMI cable and the convertor, setup the camcorder via the menu to output to both TV and the LCD screen and also setup to output to HD TV. I try and play a recorded video and it appears on the camcorder LCd but not the screen.
    I've tried a couple of different HDMI cables but still nothing. It could simply be the ebay-purchased convertor I bought but I just wanted to know if anyone else has had any problems?
    Do I need to buy an actual Sony cable? Had a quick look on Amazon and they cost almost £30...this is a quite a lot for a cable that I will only use now-and-again.
    As a side-note, I didn't have the camcorder plugged into the mains at the time, I was running it from the battery which I assume should be fine since it outputs fine via component cables.
    Cheers
    Wayne
  2. Member edDV's Avatar
    Give the link to this "converter". All you should need is an HDMI to HDMI cable.
    Also ID the model number for the camcorder.
    http://www.kiva.org/about
  3. Member edDV's Avatar
    According to this picture, the Sony HDR-SR12E has a normal HDMI connector. A simple HDMI-HDMI cable should work.
    http://detail.zol.com.cn/picture_ind...x1812356.shtml
    this is the connector i bought:-
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=120327902610
    The camcorder requries a mini-HDMI connector, hense the connector above.
    The model number of the camcorder? It's a HDR-SR12E as per the topic title. Unless I'm missing something? Please ask if you need more details.
    Cheers
    Wayne
  5. Member edDV's Avatar
    Cheers
    Wayne
    OK that should work HDMI to HDMI. Have you read the manual about settings to get an HDMI output? Maybe a call to Sony support is most efficient. Few of us own that particular camcorder model.
    yep, i think you're right. i'll give it a go. Thanks for the advice.
    Cheers
    Wayne
  1. Replies: 16
    Last Post: 25th Feb 2012, 16:20
  2. SONY HDR-AX2000E: "only" 1080i via HDMI, not 1080p?
    By flashandpan007 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Jul 2011, 04:50
  3. Sony-SR12E(PMB Problem)
    By s.o.n.ymyself in forum Mac
    Last Post: 29th Oct 2009, 03:11
  4. hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
    By deejay.2001 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Aug 2008, 16:28
  5. HDMI 1.3 cable with Sony 40W3000 Lcd Tv
    By budz in forum DVB / HDTV
    Last Post: 26th Dec 2007, 20:47
