VideoHelp.com Forum
Results 1 to 11 of 11
    If anyone can help i'd really appreciate it, this is the second time it has happened
    I ordered a movie on VHS and when i tried to play it the screen is black or blue, there seems to be some audio though so i have no idea what to make of it, was i ruined during shipping? erased when it went through security or something?
    Does anyone know why it doesn't play and if there is any way to fix it?
  2. I'm a Poll Super Moderator johns0's Avatar
    Try adjusting the tracking,also check to see if the tape is ntsc or pal,if you are in ntsc land and the tape is pal then you wont be able to see the picture.
    Ben Johnson-I didnt take any stereos!
    i looked on the case and tape and couldn't see pal etc
    i'm in canada and it's from france, i knew there were different regions for dvd but i didn't know they had that for vhs, assuming that is the issue is there anything i can do? no eh
  4. Member Number Six's Avatar
    If I remember correctly - France used SECAM. Does the tape say that anywhere?
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
    yeah it says VHS SECAM-EDV3 so it's a compatibility problem, is there anywhere i could take it and get the formats fixed or something like that or am i just screwed?
  6. Member Number Six's Avatar
    Years ago there were photo and video stores that transferred tapes from one format to another, but I think most of them are gone now - and I do not know what services are available in Canada. Try to do a local search in your area.
    I just did a quick search on eBay for multi format VCRs - they are available, but expensive - probably not worth it unless you plan on expanding your video library.
  7. Member Soopafresh's Avatar
    I've seen a lot of mom and pop places that convert various VHS tape formats here in the States, in particular British and Russian imports retail stores. If you live in a bigger city, there should be something similar.
    i live in a decent sized city, hopefully i'll find one, thanks for your help guys
  9. Member Number Six's Avatar
    Glad to be of service
  10. Video Restorer lordsmurf's Avatar
    French SECAM is a SECAM format of its own, SECAM-L. It's the one SECAM even I cannot convert. It takes much rarer equipment than your normal PAL or SECAM players. Leave it to the French.
  11. A friend of mine bought a movie on vhs once and it was completely blank, just a blank vhs tape. I couldn't stop laughing.
  1. Replies: 1
    Last Post: 6th Oct 2009, 00:09
  2. How to Replace/Distort Uncensored Scenes in a movie with Blank
    By ishopper in forum Newbie / General discussions
    Last Post: 30th Sep 2009, 00:54
  3. Replies: 23
    Last Post: 21st Sep 2009, 21:17
  4. Are they still making vhs blank tapes?
    By heman31 in forum Restoration
    Last Post: 13th Apr 2009, 17:04
  5. Inserting blank frames with logos before movie start
    By multiplex in forum Newbie / General discussions
    Last Post: 1st Oct 2008, 20:30
