    Nov 2008
    I have a .ts file. I am doing some work testing a bug in a streaming engine. I need a way to edit the header to change the sync byte from 0x47 to something else. Does anyone know of a tool that would enable me to do this? The bug is in how we handle streams that have bad sync byte, so need to reproduce.
  2. Banned
    Freedonia
    If no one has a better idea, you should be able to do this with a binary editor but doing so will require you to know how to use a binary editor and to know the location of the sync byte so you can change the correct thing in the stream.
