VideoHelp.com Forum
    Hi guys
    Windows cannot initialize the device driver for this hardware. (Code 37)
    I have searched the forum and found a similar problem way back in 2005 but unfortunately nothing listed has worked. I've tried:
    Uninstalling and reinstalling DVD driver & IDE
    Updating / rolling back driver software
    Downloading a registry edit (CDGONE.reg)
    System restore back about one week
    Windows Help... haha!
    The device still doesn't work. It is internal in my laptop and has worked fine.
    Any ideas gratefully received.
    Cheers, Marcus
  2. Mod Neophyte Super Moderator redwudz's Avatar
    It's tough to work with a laptop drive as it's difficult to pull it out and try in another computer. But my guess is the drive is the problem. If you could boot to a Linux or PE disc, you could rule out the OS as the problem. Maybe from a USB thumb drive.
    If you have to give up on it, consider a USB external optical drive. I've replaced the optical drive in one laptop and it can be a major project, besides being very expensive.
    And have you looked in the BIOS settings to see if the drive shows there? It should show in BIOS even without the system drivers loaded.
    It would also be helpful to tell us your laptop brand and model as others may have knowledge of the problem.
    And welcome to our forums.
    I just had a problem with a device driver in vista I think it was code 39 driver is corrupted or missing there was an entry in the registry I had to remove in the cd/dvd driver section you may want to look at that section of the registry the tech at lenovo told me it was probably put there by a program I installed all I did was delete it and the driver installed when starting up windows
  4. I'm a Poll Super Moderator johns0's Avatar
    Did a search in google and found this fix:
    http://forums.techarena.in/xp-hardware/619881.htm
    Ben Johnson-I didnt take any stereos!
    that is what I did to fix mine
  1. Replies: 8
    Last Post: 21st Dec 2011, 19:31
  2. need region code for Insignia NS dvd 1-A player
    By gegely in forum DVD & Blu-ray Players
    Last Post: 1st Mar 2009, 17:05
  3. unlocking code not working LG LH T550
    By adonisuk in forum Newbie / General discussions
    Last Post: 27th Jun 2008, 13:21
  4. Sony DAVDZ230 dvd player code
    By jim321 in forum Newbie / General discussions
    Last Post: 5th Mar 2008, 14:01
  5. Code is not working on Polaroid PDX-0073, HELP!
    By Joppie in forum DVD & Blu-ray Players
    Last Post: 23rd Sep 2007, 12:46
