Thread: KW-AVX800
    Hi!
    I have a JVC KW-AVX800 dvd player. It doesnt play dvd's as whenever i put one in it says there is a region code error.
    How do i get it to work?
    thanks
  2. Member Krispy Kritter's Avatar
    Most likely you are attempting to play dvd's from a different region. Not all players can be made region free. You can look in the DVD Hacks section or try google. Otherwise, you will need to get a player that supports region free.
    Google is your Friend
    You can also rip the DVDs to your hard disk and reburn them. Ripping will remove the region coding. I know that's an extreme suggestion, but it is a possibility if you can't unlock the player's region.
About   Advertise   Forum   RSS Feeds   Statistics   Tools
