VideoHelp.com Forum
    Hi
    i have a sony bravia lcd 32" TV and a Sony RDR-HX720 with me.I am planning to buy a surround sound system which i can use with the above two.I did some search and found this system.Sony HT-SS2300.I would like to know about the performance of Sony HT-SS2300 and also whether it is compatible with Sony RDR-HX720
  2. Member Krispy Kritter's Avatar
    Your only consideration would be the audio outputs from your player, which should likely be optical/coaxial digital. You simply need to find a system or AVR which has the inputs needed for your player.
    Google is your Friend
  1. Copying From Sony RDR HX720 to laptop
    By abdul_sma in forum DVD & Blu-ray Recorders
    Last Post: 30th Aug 2010, 07:46
  2. Sony RDR-HX720 problem with divx
    By giltic in forum DVD & Blu-ray Players
    Last Post: 10th Apr 2009, 13:07
  3. Good Surround Sound for Sony RDR-HX720
    Last Post: 6th Nov 2008, 09:23
  4. Sony RDR-HX720 compatibility with Home Theater
    Last Post: 13th Jan 2008, 22:44
  5. Sony RDR-HX750
    By woutie in forum DVD & Blu-ray Recorders
    Last Post: 14th Sep 2007, 09:54
