If you use a software like Fair Use Wizard to convert a DVD to avi sub/idx and the resulting subtitles are the wrong color,
First step (may be optional). Convert sub/idx to sup using Subtosup
Then use Subtitle Creator. Under Format, choose ntsc or pal, then Tools>Manipulate sup or Vobsub.
In new window click Open Sub and input your sub/idx or sup
Then change colors to be like in the screenshot:
Color 0 Black and tick transp
Color 1 Black
Color 2 White
Color 3 Black
Click Apply to All
And Save Sub as idx/sub
This will give subtitles with white letters with a black outline.
Great solution. Thanks
I'm a SPAMMER
What version what this in ? It doesn't appear to be in the latest version.
With that setting letters go black, better to use:
Color 0 = black with transp tick
Color 1 = white
Color 2 = black
Color 3 = grey
ffmpegX - idx/sub subtitles lost in converting from avi to Xvid or DivX
By bonespur in forum MacReplies: 5Last Post: 4th Mar 2011, 02:25 -
How do I convert DVD to sub/idx or text srt COLOR subtitles?
By kkm in forum SubtitleReplies: 1Last Post: 19th Mar 2010, 13:08 -
What am I doing wrong? AVI to DVD with srt subtitles.
By du2vye in forum ffmpegX general discussionReplies: 8Last Post: 21st Oct 2009, 12:54 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10 -
Mux avi + audio, something wrong, an issue ? (solved by myself)
By sepulcrio in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jan 2008, 11:11
