VideoHelp.com Forum
Thread: MeGUI problems
  1. Problem 1: I think I have tried everything- uninstalled MeGUI, restarted, freshly installed meGUI and updated MeGUI again- online. Reinstalled AVISynth last stable version. Checked carefully and found that TIVTC.dll is there in the AVISynth plugins directory.
    Whenever I try to analyze the source I always get this error. So I can not analyze the source.
    Please give me a solution for this
    Here is my system spec:
    MeGUI Version : 0.3.0.3006
    TIVTC.dll version: 1.0.5 (latest, i have checked the homepage)
    OS : Microsoft Windows XP Professional SP2 (5.1.131072.2600)
    Framework used : 2.0 (2.0.50727.42)
    Hardware
    CPU : Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz
    Please help
    Problem 2: There is one more problem I am facing while trying to encode in Xvid. MeGUI simply stops at this window:
    Here is the log:
    [Error] Log
    -[Information] Versions
    --[NoImage] MeGUI Version : 0.3.0.3005
    --[NoImage] OS : Microsoft Windows XP Professional SP2 (5.1.131072.2600)
    --[NoImage] Framework used : 2.0 (2.0.50727.42)
    -[Information] Hardware
    --[NoImage] CPU : Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz
    -[Warning] Log for job3 (audio, My Movie T80 3_2ch 384Kbps DELAY 6ms.ac3 -> My Movie T80 3_2ch 384Kbps DELAY 0ms.ac3)
    --[Information] [10/28/2008 12:08:14 AM] Started handling job
    --[Information] [10/28/2008 12:08:14 AM] Preprocessing
    --[NoImage] Avisynth script
    ---[NoImage] NicAc3Source("J:\Temp\My Movie T80 3_2ch 384Kbps DELAY 6ms.ac3", DRC=1)
    ---[NoImage] DelayAudio(6.0/1000.0)
    ---[NoImage] ConvertAudioToFloat()
    ---[NoImage] Normalize()
    ---[NoImage] 6<=Audiochannels(last)?GetChannel(last,1,3,2,5,6,4 ):last
    ---[NoImage] ConvertAudioTo16bit()
    ---[NoImage] return last
    --[NoImage] Commandline used: -i - -y -acodec ac3 -ab 384k "{0}"
    --[Information] [10/28/2008 12:08:14 AM] Encoding started
    --[Information] [10/28/2008 12:08:14 AM] Encode thread started
    --[Information] [10/28/2008 12:08:14 AM] Avisynth script environment opened
    --[Information] [10/28/2008 12:08:15 AM] Script loaded
    --[Information] Input
    ---[NoImage] Channels: 6
    ---[NoImage] Bits per sample: 16
    ---[NoImage] Sample rate: 48000
    --[NoImage] Commandline: D:\Applications\2_Video Tools\megui\tools\ffmpeg\ffmpeg.exe -i - -y -acodec ac3 -ab 384k "J:\Temp\My Movie T80 3_2ch 384Kbps DELAY 0ms.ac3"
    --[Information] [10/28/2008 12:08:15 AM] Encoder process started
    --[Warning] Deleting aborted output
    ---[NoImage] Delete aborted ouptut set: True
    ---[NoImage] File to delete: J:\Temp\My Movie T80 3_2ch 384Kbps DELAY 0ms.ac3
    ---[Warning] Error deleting file
    ----[NoImage] Exception message: The process cannot access the file 'J:\Temp\My Movie T80 3_2ch 384Kbps DELAY 0ms.ac3' because it is being used by another process.
    ----[NoImage] Stacktrace
    -----[NoImage] at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    -----[NoImage] at System.IO.File.Delete(String path)
    -----[NoImage] at MeGUI.core.gui.JobWorker.markJobAborted()
    ----[NoImage] Inner exception: null
    -[Error] Error attempting to stop processing
    --[NoImage] Exception message: Object reference not set to an instance of an object.
    ---[NoImage] at MeGUI.AviSynthAudioEncoder.stop()
    ---[NoImage] at MeGUI.core.gui.JobWorker.Abort()
    ---[NoImage] Exception message: Object reference not set to an instance of an object.
    ---[NoImage] Stacktrace: at MeGUI.AviSynthAudioEncoder.stop()
    Note: I have latest K-Lite Mega Codec Pack installed.
    I have posted these problems in the MeGUI thread in Doom9, but did not get any solution
    Could someone please help?
    আমি বাংলায় গান গাই
  2. Any help please?
    আমি বাংলায় গান গাই
    you should maybe uninstall k-lite and install cccp codec pack instead. But i don't think it maks any difference anyways.
  1. Is anyone else having problems with MeGUI update?
    By Xpenguin17 in forum Newbie / General discussions
    Last Post: 25th Jul 2010, 18:44
  2. Replies: 4
    Last Post: 28th Mar 2010, 20:54
  3. Problems with audio sync in MeGUI
    By Sutekh in forum Newbie / General discussions
    Last Post: 13th Sep 2009, 14:57
  4. Problems with audio sync in MeGUI
    By Sutekh in forum DVD Ripping
    Last Post: 13th Sep 2009, 14:48
  5. meGUI problems...
    By FallenAngelII in forum Video Conversion
    Last Post: 23rd Aug 2007, 17:20
