Results 1 to 11 of 11
    Hello,
    Please advice me what should i do. My DVDR does not start. It only shows up on the dispay message "Starting.." and the light Hdd Active is on (this even when my hdd is removed) and only a white screen with the logo Philips shows on my tv.
    I whant to mention that i connected the HDD to my pc and formated it.
    Now what i want to ask is if i need some driver for my DVDR3595H copied on the hdd ? or what should i do next ?
    Thank you all.
    Hi All,
    I have the same problem.
    MArekk did you already solved the problem? If so how?
    Rgds
    Hi,
    No i didn't solved my problem. I still looking for some help.. In this forum like i can see no one is willing to help
    If you solve sooner than me, please contact me
    Thanx
    i have this problem also,hope i can get it fixed,please let me know if any of you lads fix it...
    i didn't fix it yet
    still need help
    Well, it's not that nobody wants to help, it's that probably nobody knows the answer to your problem. I live in the USA and here in North America, almost all of the companies have stopped making DVD recorders for us. I don't know if that model was ever sold here. The only Philips DVD recorders that I know of that were sold here were earlier models than what you have. So what I want to say is that probably nobody in North America knows the answer to your question and that removes a lot of potential help.
    You might try to ask here:
    http://www.avsforum.com/avs-vb/forumdisplay.php?f=106
    thanks
    I Hope this info is of use to you all. I know it works with the Irish/UK model DVDR3595H/05 probably for other models too.
    DVDR3595H/05
    Self Test
    Press and hold the REC and Play (>|) keys*on the front panel of the set*while powering on the mains. Release buttons when Philips logo screen displays*on TV- *"NUC 100" will be displayed on local LED display Then "NUC503 " for a few minutes, followed by several NUC numbers in quick succession and finally "PASS".
    To Format HDD
    1) Unplug the set from the mains.
    2) Press and hold the BACK (|<<)and STOP keys*simultaneously on the front panel of the set*while powering on the mains.*- Release keys when machine starts*
    3) "FMT KEY" will be displayed on local display, followed by FMT HDD and FMT DONE
    DVD Region hack
    1. Turn on the player from the front panel (without a disc inserted)
    2. Press HDD List on remote and ensure Hard Disk is highlighted
    3. Press PLAY
    4. Enter 159 121 212 005 255
    5. Press PLAY
    6. Turn the player off
    Firmware Update
    You can resolve other problems by upgrading the set with the latest software (V3.06) now available on the Philips support website.
    http://www.care.philips.com/support
    Proceed with the following steps to upgrade the set:
    1) Download the required zipped file from the website
    2) Unzip and burn content of the zipped file to the root i.e. x:\ of a CD-R/CD-RW disc (Note: There should not be any folders on the disc).
    3) Unplug the set from the mains.
    4) Press and hold the REC and NEXT (>>|) keys*on the front panel of the set*while powering on the mains.*- *"Download" will be displayed on local display.
    5) After sometime, the tray will be ejected.*- Insert disk and close tray
    6) Place the download disc on the tray and push in the tray.*- The downloading process will begin. It should take around 7mins.
    7) After the download is completed, tray will be automatically ejected. Remove the disc and push in the tray, wait till you see "DONE" on the local display (LD). Set may restart several times during this process.
    8) The set will be able to wake up and proceed to the first installation screen.
    Thanks Cork, got my hdd back in the game
    Thank you Cork ,
    I just joined this forum to thank you .
    I had a dvdr3595h , that i think i had reflashed firmware but kept " starting " !!!
    I did 1 selftest and 2 format HDD , as above , and now works OK !
    It was actually a philips dvdr3595H / 58 , as sold in Greece . Thanks , again !
  1. Philips DVDR3595H
    By nvlokhov in forum DVD & Blu-ray Players
    Last Post: 10th Dec 2007, 14:07
  2. 250GB internal HD only reading as 32GB???
    By videotape74 in forum Computer
    Last Post: 21st Mar 2007, 16:39
  3. 250GB DVDs?
    By Doramius in forum Latest Video News
    Last Post: 25th Nov 2005, 12:27
  4. 250GB Drive dying
    By fmctm1sw in forum Computer
    Last Post: 28th Apr 2005, 09:04
  5. What would you do with a 250GB drive in this case?
    By fmctm1sw in forum Newbie / General discussions
    Last Post: 19th Oct 2004, 09:15
About   Advertise   Forum   RSS Feeds   Statistics   Tools
