VideoHelp.com Forum
Results 1 to 9 of 9
    I have a video file that I filmed on my digital camera. I am trying to work with it and it acts fine at first, but then in five minutes I get an error and Premiere is closing. After that when I try to open my project, I get an error right a way. It doesn't even get to load.
    What could be a problem? I really need to fix this and get back to my project as soon as possible......
    Please give us a bit more information about your source file. DV-AVI? Or what video and audio codec and what container(avi,mp4,mov,etc identify using MediaInfo if you don't know)?
    And Premiere is an editor so moving you to our editing section.
    Thanks for the info and sorry it took me long to reply. I was outside of home for a vacation and I am back now.
    I downloaded that program and took a screenshot as I am not sure what exact info you need:
    I am not sure what DV-AVI is and how it differs from .AVI. I don't even remember the original format. I filmed that video on my digital camera and after I had problems with it and Premiere I thought it might be the format. I was changing the format because I thought it might recode the file and give me a a proper version with no corruption. I am not sure that it IS the file that is corrupted because I tried editing it on several computers and I would always get an error after what program closes =/
    Let me know what other information/screenshots you need me to provide, in order to best describe my situation and find a solution!
    Thanks,
    will be waiting for replies.
    PS: I was clicking around and thought you might ask me for this: I clicked "Debug" -> "Advanced mode" and here is what I got:
    General
    Count : 246
    Count of stream of this kind : 1
    Kind of stream : General
    Stream identifier : 0
    Inform : AVI: 150 MiB, 8mn 6s
    Count of video streams : 1
    Count of audio streams : 1
    Video_Format_List : MPEG-4 Visual
    Video_Format_WithHint_List : MPEG-4 Visual (XviD)
    Codecs Video : XviD
    Audio_Format_List : ADPCM
    Audio_Format_WithHint_List : ADPCM
    Audio codecs : U-Law
    Complete name : C:\Users\Ervand\Desktop\SN202691.AVI
    Folder name : C:\Users\Ervand\Desktop
    File name : SN202691
    File extension : avi
    Format : AVI
    Format : AVI
    Format/Extensions usually used : avi
    Interleaved : No
    Codec : AVI
    Codec : AVI
    Codec/Info : Audio Video Interleave
    Codec/Extensions usually used : avi
    File size : 157795090
    File size : 150 MiB
    File size : 150 MiB
    File size : 150 MiB
    File size : 150 MiB
    File size : 150.5 MiB
    Duration : 486453
    Duration : 8mn 6s
    Duration : 8mn 6s 453ms
    Duration : 8mn 6s
    Duration : 00:08:06.453
    Overall bit rate : 2595031
    Overall bit rate : 2 595 Kbps
    Stream size : 370979
    Stream size : 362 KiB (0%)
    Stream size : 362.3 KiB
    Proportion of this stream : 0.00235
    File creation date : UTC 2008-11-11 13:07:16.701
    File last modification date : UTC 2008-09-26 12:07:16.632
    Writing application : SAMSUNG TECHWIN
    Original source form/Name : NV CS 103
    Video
    Count : 133
    Kind of stream : Video
    Inform : 2 525 Kbps, 640*480 (4/3), at 29.970 fps, MPEG-4 Visual (XviD) (Simple@L2) (BVOP)
    Format : MPEG-4 Visual
    Format profile : Simple@L2
    Format settings : BVOP
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : 0
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default
    Codec ID : XVID
    Codec ID/Hint : XviD
    Codec ID/Url : http://mediaarea.net/XVID
    Codec : XVID
    Codec : XviD
    Codec/Family : MPEG-4V
    Codec/Info : XviD project
    Codec/Url : http://www.xvid.org/Downloads.15.0.html
    Codec/CC : XVID
    Codec profile : Simple@L2
    Codec settings : BVOP
    Codec settings, Packet bitstream : No
    Codec settings, BVOP : Yes
    Codec settings, QPel : No
    Codec settings, GMC : 0
    Codec settings, GMC : No warppoints
    Codec settings, Matrix : Default
    Duration : 486453
    Duration : 8mn 6s
    Duration : 8mn 6s
    Bit rate : 2524989
    Bit rate : 2 525 Kbps
    Width : 640
    Width : 640 pixels
    Height : 480
    Height : 480 pixels
    Pixel Aspect Ratio : 1.000
    Display aspect ratio : 1.333
    Display aspect ratio : 4/3
    Frame rate : 29.970
    Frame rate : 29.970 fps
    Frame count : 14579
    Resolution : 24
    Resolution : 24 bits
    Scan type : Progressive
    Interlacement : PPF
    Interlacement : Progressive
    Bits/(Pixel*Frame) : 0.274
    Stream size : 153536111
    Stream size : 146 MiB (97%)
    Stream size : 146.4 MiB
    Proportion of this stream : 0.97301
    Audio
    Count : 117
    Kind of stream : Audio
    Inform : 64.0 Kbps, 8 000 Hz, 1 channel, ADPCM (U-Law)
    Format : ADPCM
    Format profile : U-Law
    Codec ID : 7
    Codec ID/Info : CCITT U-Law
    Codec ID/Url : http://www.microsoft.com/windows/
    Codec : 7
    Codec : U-Law
    Codec/Family : ADPCM
    Codec/Info : CCITT U-Law
    Codec/Url : http://www.microsoft.com/windows/
    Codec/CC : 7
    Duration : 486000
    Duration : 8mn 6s
    Duration : 8mn 6s 0ms
    Duration : 8mn 6s
    Duration : 00:08:06.000
    Bit rate mode : CBR
    Bit rate mode : Constant
    Bit rate : 64000
    Bit rate : 64.0 Kbps
    Channel(s) : 1
    Channel(s) : 1 channel
    Sampling rate : 8000
    Sampling rate : 8 000 Hz
    SamplingCount : 3888000
    Resolution : 8
    Resolution : 8 bits
    Stream size : 3888000
    Stream size : 3.71 MiB (2%)
    Stream size : 4 MiB
    Stream size : 3.7 MiB
    Stream size : 3.708 MiB
    Proportion of this stream : 0.02464
    Interleave, duration : 30.00
    Interleave, duration : 1001
    Interleave, duration : 1001 ms (30.00 video frames)
    Download and install this:
    http://www.digital-digest.com/softwa...2&ssid=0&did=1
    That's the XVID codec. Once installed, reboot the computer, restart Premiere CS3. It should now have an XVID codec in the DirectX library, which Premiere pulls from to get some of its codecs. It does not natively support MPEG-4, but will after you've got the codec installed.
    DO NOT INSTALL A "CODEC PACK"! Just install the one codec as I've instructed.
    That should be all you need.
    Didn't help.
    In fact it lead to even more problems. Now, when I single-click on the video file in a folder it gives me the following error:
    Sometimes I don't even get to click the file and it give me that error.
    One more thing. Premiere Pro was able to view and work with the file for some period of time. I tried to start a new project and I would get that problem when I get to a certain place I guess. So I really thing it is a problem with the file, not the codec.
    And just like always when I open my project it is asking me for a lost file (since I am on another computer right now) and when I finally post that avi file Premiere gives me the following error:
    and then Premiere closes.
    PS: I am able to work on my other Projects fine...
    Any ideas on how to fix the file
    Contact Adobe, something is fubar.
    fubar?
    Fouled up beyond all recognition = FUBAR
    Situation normal, all fouled up = SNAFU
  9. aBigMeanie aedipuss's Avatar
    i know this is a "pg" site but i've never heard anyone use fouled as the "f" in those acronyms.
  1. Replies: 3
    Last Post: 21st Nov 2009, 18:23
  2. Adobe Premiere CS3 error
    By tjcook1 in forum Editing
    Last Post: 23rd Sep 2009, 22:32
  3. Adobe Premiere Pro CS3 & Vegas Pro help
    By KS89 in forum Editing
    Last Post: 8th Sep 2009, 22:52
  4. SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
    By Fary4u in forum Video Conversion
    Last Post: 20th Jul 2009, 09:00
  5. Adobe Premiere pro CS3 to DVD using MP4
    Last Post: 13th Jul 2009, 12:13
