VideoHelp.com Forum
    I have a 500GB external USB Maxtor HDD. I came with NTFS. I want to use it with my Philips 5990 DVD player, which requires Fat32. I used Swissknife to create a Fat32 partition. My XP machine won't recognize the drive at all now and neither will the Philips player. It freezes my computer until I unplug the drive.
    Please help.
  2. Greetings Supreme2k's Avatar
    Try plugging it in after you boot into Windows, then use the maxtor tools to repartition and format it.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    Must have been a problem with Swissknife. I didn't have any problems when I formatted a external 320GB HDD with Swissknife using FAT32. It reads on my Vista computer OK. And it also reads properly on a 5990.
    XP (And most other Windows OSs) won't work for paritioning a hard disc over 32GB to FAT32, that's what Swissknife is for. Unless Maxtor Tools can do that?
    Swissknife is very fast. (And I thought foolproof.) I'd try running it through again. A full FAT32 drive may read a bit slow, but since it's going to use a USB interface, I doubt you will notice. I stuffed over 400 Xvids on a 320GB drive. I used this method from bwd777 to set up the HDD: http://www.videohelp.com/dvdplayers/...90/9370?#70038
    Yep. That was it. I was able to reformat the drive correctly this time using Swissknife. XP sees it and so does the 5990.
    Thanks!
    I have this problem and i cannot get my hdd to show up at all. Not great with computers so lamens terms would be great...
  6. Mod Neophyte Super Moderator redwudz's Avatar
    We would need a bit more information.
    What brand and model of external hard drive?
    Capacity?
    Does it work on a computer?
    What brand and model of DVD player?
    Is the drive plugged directly into the player, no hubs?
    Does a USB flash drive work with the player?
    Is it formatted as FAT32? (Plug it into a computer, R click on the drive and select 'Properties'. You should see 'FAT' in the file system info box.)
    And welcome to our forums.
    Ok well i finally got it to pop up, but i still cant get swissknife to work on it. It is a maxtor onetouch 4. 500gb usb 2.0 and it is NTFS
  1. Replies: 5
    Last Post: 18th Feb 2011, 03:04
  2. Replies: 4
    Last Post: 24th Sep 2010, 13:41
  3. Fat32/NTFS External Hard Drive Formatting Questions.
    By bbanderic in forum Newbie / General discussions
    Last Post: 23rd Jan 2010, 21:13
  4. Formatting WD my passport to fat32
    By 41i3n777 in forum Computer
    Last Post: 9th Sep 2009, 20:12
  5. HDD problem NTFS vs FAT32
    By edsmith77 in forum Computer
    Last Post: 21st May 2007, 11:17
