VideoHelp.com Forum
    hey,
    the ffmpegX components self-installer keeps giving me this message:
    WARNING: Improper use of the sudo command could lead to data loss
    or the deletion of important system files. Please double-check your
    typing when using sudo. Type "man sudo" for more information.
    To proceed, enter your password, or type Ctrl-C to abort.
    I've tried everything the site tells me to, and still no luck. also, when trying to download the link mpeg2enc directly from the link by using the ctrl click, i do not have the option on the menu that pops up. the mencoder and mplayer didnt give me any problems though. any ideas?
  2. Explorer Case's Avatar
    Does your admin account have a password? It should; the installer will use the "sudo" command in the background, which needs a non-blank password.
    Does your password have special characters in it? The installer doesn't like that either. If so, try changing the password (in System Preferences > System > Accounts) to something 'simple', with only letters and/or numbers.
    As for downloading mpeg2enc: control-clicking a link should give you a contextual menu with an option to download whatever is behind that link. 'Download Linked File' in Safari, or 'Save Link As' in Firefox.
  1. Trouble with component usb cap device.
    By roy.walters in forum Capturing
    Last Post: 15th Dec 2011, 20:12
  2. Trouble Editing/Trouble Base Media?
    By SlickPen in forum Editing
    Last Post: 20th Mar 2011, 19:53
  3. trouble finding install files snow leopard 10.6.2
    By bookerfatz in forum ffmpegX general discussion
    Last Post: 2nd Feb 2010, 16:52
  4. Can't install outdated component
    By ripper389561 in forum ffmpegX bugs and suggestions
    Last Post: 26th Jan 2009, 18:28
  5. Replies: 2
    Last Post: 5th Apr 2008, 13:43
