I have free Avast installed, cannot find any menu to turn off auto updates ??.
As a result I now have a free trial version installed with 22 days to update to Avast Pro.
Right click on the Avast icon on the toolbar and select Program Settings. In there you can select Manual for updates.
you think the timer will stop if you disable the update?
The free,and the pro both share the same engine/AV definition is just the pro got more options that it -
When you installed it you did register it and get your free serial number didn't you? If you install it without registering the built in serial will revert to a trial mode if I'm not mistaken.
AVAST - Who Are They ???
By blinky88 in forum ComputerReplies: 15Last Post: 24th May 2012, 06:25 -
Avast
By Jomapil in forum ComputerReplies: 2Last Post: 3rd Mar 2012, 12:35 -
How to stop Ripbot from auto deleating the temp file?
By cal_tony in forum Video ConversionReplies: 0Last Post: 5th Feb 2010, 14:36 -
Avast Free Home Goes Bonkers!!!!
By hech54 in forum ComputerReplies: 29Last Post: 7th Dec 2009, 13:32 -
Capture stop because no free space->corrupt avi
By RH+ in forum CapturingReplies: 3Last Post: 30th May 2007, 10:01
