VideoHelp.com Forum
    Hi,
    I'm using TSMuxer to put m2ts files back together but when I load each individual m2ts, I get the error: "Some tracks not recognized. This track was ignored." and then I can't see the English DTS track that I need...is there any way I can get around this?
    did you use anydvd first?
    you can try doing it in eac3to, which tends to detect tracks better.
    Yes, I ripped the BD onto my HDD...but it has seamless branching...so the m2ts files are all over the place...my guess is because there is a theatrical and unrated cut on the disc.
    So I load the BDMV folder in BDEdit and find out what the sequence should be and then add the m2ts files in order into TSMuxer...but each file generated the aforementioned error.
    I need some way of parsing all these m2ts files into one large m2ts with just AC3 5.1 audio...
  1. Extracting DTS-HD track with tsmuxer
    By rantonio in forum Blu-ray Ripping
    Last Post: 18th Mar 2011, 08:23
  2. DTS-HD Master Audio Extraction from Tsmuxer
    By m1ke486837 in forum Blu-ray Ripping
    Last Post: 5th Jan 2011, 19:29
  3. DTS Audio Issue?
    By jboogie713 in forum Audio
    Last Post: 8th May 2010, 14:40
  4. downconverting HD Audio in TsMuxer issue
    By Modify_inc in forum Blu-ray Ripping
    Last Post: 21st Jul 2009, 10:20
  5. Replies: 0
    Last Post: 1st Jun 2009, 09:46
