VideoHelp.com Forum
    Hi ,
    is there any way of stopping ts muxer changing the resolution of mkv files that i convert to bluray.
    It seems to change it from the original eg - 1280 x 528 to 1280 x 720 causing the picture to stretch and everyone look too tall. lol!
    I would rather keep it the same as the original file if this is possible or make it so it doesnt stretch some other way without too much messing around.
    thanks in advance.
    Bobo.......
    Stand alone blu-ray units can only play "regular" resolutions (ie. 1280x720, 1920x1080)
    You would have re-encode and AddBorders(0,96,0,96) in avisynth to maintain the aspect ratio
    ie. (720-528)/2 = 96 pixels to the top and bottom
    It be easier to use the original bluray disc
    thanks for the info , think ill try add some borders when i have more time
    If at first you don't succeed........
    Ask someone that knows what there talking about !!!!!
  4. Member PuzZLeR's Avatar
    Probably that's how the streams were before MKV. The aspect ratio was adjusted at the container level when muxed into the MKV and the streams return to "normal" when demuxed probably even before using TsmuxeR - which isn't supposed to change the file. Did you play them raw first before TsmuxeR?
    Then again, I've never, ahem, encountered one of these "special" MKVs.
    Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
    Those "special mkv's" are nothing more than blu-ray rips with borders cropped. Most Hollywood movies will not have a DAR of 1.778, rather DAR 2.35, so the original blu-ray will have borders to keep the full 1920x1080 frame which is necessary for blu-ray compatibility. Container flags are usually untouced in the .mkv backups, and PAR is usually 1:1, so DAR=FAR.
    If you attempt the silliness of mkv=>blu-ray you just have to add the borders back to keep the original aspect ratio of the blu-ray; if you don't the aspect ratio will be distored as described by the OP when you stretch to full frame without borders.
    and how do you add borders? I am a newbie using ripbot and I dont know how
    how exactly do i get tsmuxer to automatically change the resolution
    I want this problem to occur for me
  1. Ts Muxer Blues
    By romanticwarrior in forum Authoring (Blu-ray)
    Last Post: 2nd Dec 2010, 08:17
  2. RMVB Subtitle Muxer
    By El Heggunte in forum Subtitle
    Last Post: 11th Jul 2010, 20:49
  3. FLV/mkv muxer
    By ayim in forum Video Conversion
    Last Post: 4th Feb 2010, 00:31
  4. H.264 encoder with TS muxer
    By kary.sharma in forum Video Conversion
    Last Post: 30th Dec 2008, 02:35
  5. menc muxer problem ?
    By Ahmed28 in forum Newbie / General discussions
    Last Post: 10th Nov 2008, 06:27
