Hi,
I've been a Network/Systems Engineer for about 10 yrs now and you would think I could figure this one out
but alas I humbly bow to the experts for advice.
I need to burn a slide show of pictures w/ sound on a DVD to be played in DVD players.
I have the show set up and ready to go and am ready to burn.
My question is which media is best to use that will play on most payers for this type of project?
Does r,w r+w, etc....matter?
I've nosed around a bit in the forums but It's just confusing me more
Thanks!!
For best results, use either DVD+R or DVD-R. Do NOT use DVD+RW, DVD-RW or any DL media.
DVD-R is marginally more compatible than DVD+R. If you use DVD+R, you may need to set book type in your burner, if your burner allows it. This is a trick that fools older DVD players that think they can't play DVD+R discs into playing them because the disc identifies itself as DVD-ROM, which they can play. This nonsense is not required on modern DVD players and I don't worry about it, but if you don't know how old and/or crappy these DVD players might be, you might want to just stick to DVD-R. DVD-R doesn't require this special setting to work. Re-writable DVD discs and DL discs may have compatibility problems with some older players and should be avoided unless you are sure they will work.
Verbatim and Taiyo Yuden (you'll have to mail order these) are the only reliable DVD manufacturers that sell their discs in the USA. All other brands are inferior.
For best results, burn with the free ImgBurn program.
Great!
That's just what I needed.
Thanks jman
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
It seems that almost any big name brand -R media has wide compatibility today.
DVD-R is marginally more compatible than others...
Noob convertion question
By Bob-bob-bob-bob in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2012, 12:14 -
Noob, hoping to get some advice...setting up media center pc.
By KidCastro in forum Media Center PC / MediaCentersReplies: 7Last Post: 12th May 2010, 09:30 -
Noob HD/Bluray Question
By Startropic1 in forum Newbie / General discussionsReplies: 5Last Post: 16th Jun 2009, 15:04 -
noob question about muxing.
By Onime no Kyo in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2009, 09:33 -
Help a noob with some media questions for my Xbox and portable player
By Sulsa in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2008, 14:41
