VideoHelp.com Forum
    I'd like to know, what would be a better way to encode an audio for a video, AC-3, Mpeg layer 2 or Linear PCM?
    I have videos with this 3 of those, and i thought to encode them all to one of them, so they would work in the same way.
  2. Member gadgetguy's Avatar
    Is this for DVD? Assuming it is, if you have the room, Linear PCM is the best. AC-3 is the second most compatible format. Also assuming you are in NTSC land then technically, MP2 is not supported as primary audio for DVD, although most players will play it anyway.
    Buy My Books
  3. Man of Steel freebird73717's Avatar
    PCM is probably the best but requires alot of space. If you are using dvd5 that can really degrade video quality. AC3 is what is used most often and is IMO the best as far as quality versus size. While MP2 will play in most dvd players it is not technically in the dvd specs(at least in NTSC realm. I think it is in the specs for PAL). PCM and AC3 are.
    Best comprimise between size and quality is AC3 at a decent bitrate.
    edit- gadget guy beat me to it.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    thanks. yes, I'll be using the dvd 5 . so i better not use, the PCM. than i'll use AC3. thank you.
  5. Member AlanHK's Avatar
    Use Aften to make AC3, there are GUIs available at the link.
  1. questions about audio normalizing and audio encoding
    By codemaster in forum DVD Ripping
    Last Post: 25th Sep 2011, 21:22
  2. AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
    By arcooke in forum Newbie / General discussions
    Last Post: 5th Aug 2010, 14:18
  3. Help with audio encoding
    By tooonami in forum Linux
    Last Post: 11th Jul 2009, 18:55
  4. Replies: 1
    Last Post: 7th Jan 2009, 16:42
  5. Replies: 8
    Last Post: 21st Nov 2007, 19:53
