VideoHelp.com Forum
    I'm trying to take video files from EYETV, export them as "MPEG ELEMENTARY STREAMS", and then use ffmpegX (VER 0.0.9y) to mux the .mpv and .ac3 file - which I plan to use "BURN" to create a "DVD (UDF)" project for burning to a DVD. This process I found at http://forums.macrumors.com/showthread.php?t=245426 - posted by "Revlimit Punk". My issue is this: When I get to the mux portion of ffmpegX, there are always failures. I have done some searching around in these forums, and I can't find anybody using MUX to do this on ffmpegx....
    **ERROR: [mplex] MUX STATUS: Frame data under-runs detected!
    Any help would be greatly appreciated!!!!
    The whole log:
    INFO: [mplex] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
    INFO: [mplex] File /Users/xxx/Desktop/M*A*S*H - Major Fred C. Dobbs.mpv looks like an MPEG Video stream.
    INFO: [mplex] File /Users/xxx/Desktop/M*A*S*H - Major Fred C. Dobbs.ac3 looks like an AC3 Audio stream.
    INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [mplex] Found 1 audio streams and 1 video streams
    INFO: [mplex] Selecting dvdauthor DVD output profile
    INFO: [mplex] Multiplexing video program stream!
    INFO: [mplex] Scanning for header info: Video stream e0 (/Users/xxx/Desktop/M*A*S*H - Major Fred C. Dobbs.mpv)
    INFO: [mplex] VIDEO STREAM: e0
    INFO: [mplex] Frame width : 640
    INFO: [mplex] Frame height : 480
    INFO: [mplex] Aspect ratio : 4:3 display
    INFO: [mplex] Picture rate : 29.970 frames/sec
    INFO: [mplex] Bit rate : 8200000 bits/sec
    INFO: [mplex] Vbv buffer size : 229376 bytes
    INFO: [mplex] CSPF : 0
    INFO: [mplex] Scanning for header info: AC3 Audio stream 00 (/Users/xxx/Desktop/M*A*S*H - Major Fred C. Dobbs.ac3)
    INFO: [mplex] AC3 frame size = 768
    INFO: [mplex] AC3 AUDIO STREAM:
    INFO: [mplex] Bit rate : 24576 bytes/sec (192 kbit/sec)
    INFO: [mplex] Frequency : 48000 Hz
    INFO: [mplex] SYSTEMS/PROGRAM stream:
    INFO: [mplex] rough-guess multiplexed stream data rate : 8569944
    INFO: [mplex] target data-rate specified : 10080000
    INFO: [mplex] Setting specified specified data rate: 10080000
    INFO: [mplex] Run-in delay = 9009 Video delay = 9009 Audio delay = 18018
    INFO: [mplex] New sequence commences...
    INFO: [mplex] Video e0: buf= 0 frame=000000 sector=00000000
    INFO: [mplex] Audio bd: buf= 0 frame=000000 sector=00000000
    ++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=337334 required(DTS)=9009
    ++ WARN: [mplex] Video e0: buf= 227945 frame=000120 sector=00001245
    ++ WARN: [mplex] Audio bd: buf= 15549 frame=000131 sector=00000050
    INFO: [mplex] STREAM bd completed @ frame 38674.
    INFO: [mplex] STREAM e0 completed @ frame 36250.
    INFO: [mplex] Multiplex completion at SCR=111362925.
    INFO: [mplex] Video e0: buf= 193544 frame=036250 sector=00418750
    INFO: [mplex] Audio bd: buf= 9984 frame=036249 sector=00014734
    INFO: [mplex] VIDEO_STATISTICS: e0
    INFO: [mplex] Video Stream length: 845115762 bytes
    INFO: [mplex] Sequence headers: 2782
    INFO: [mplex] Sequence ends : 0
    INFO: [mplex] No. Pictures : 36251
    INFO: [mplex] No. Groups : 2782
    INFO: [mplex] No. I Frames : 2782 avg. size 41077 bytes
    INFO: [mplex] No. P Frames : 9302 avg. size 29952 bytes
    INFO: [mplex] No. B Frames : 24168 avg. size 18710 bytes
    INFO: [mplex] Average bit-rate : 5462800 bits/sec
    INFO: [mplex] Peak bit-rate : 6715600 bits/sec
    INFO: [mplex] BUFFERING min 15 Buf max 151574
    INFO: [mplex] AUDIO_STATISTICS: bd
    INFO: [mplex] Audio stream length 29702400 bytes.
    INFO: [mplex] Frames : 38675
    INFO: [mplex] BUFFERING min 67 Buf max 5251
  2. Explorer Case's Avatar
    1/ I'm not sure what, if anything, you can do about frame data under-runs, except try other software for the same procedure.
    2/ Can't your EyeTV software save as 'MPEG Program Stream'? Then it would already be muxed.
    3/ You could give MPEG Streamclip a try. Open the .mpv file. MPEG Streamclip will find the .ac3 audio file by itself, if it is located in the same folder with a matching name. 'Convert to MPEG' will take both elementary streams and mux them as an .mpeg file for further processing.
    EYETV will allow for export of MUX'd Stream, but I don't think I would be able to burn the resulting file using the "UDF" format. I will take a look at mpeg streamclip. Thank You!
  1. Replies: 3
    Last Post: 1st Feb 2010, 10:10
  2. Trying to mux / demux
    By GLE3 in forum Newbie / General discussions
    Last Post: 18th Dec 2009, 12:07
  3. Mux/Demux Bug
    By cefn in forum Video Conversion
    Last Post: 3rd Jun 2008, 13:09
  4. Mux audio
    By jgv115 in forum Editing
    Last Post: 18th May 2008, 01:56
  5. h264 + ac3... .mkv mux in synch, .avi mux out of synch...
    By homerpez in forum Video Conversion
    Last Post: 5th May 2007, 05:42
