I have a 1080p movie mkv file which is 8.3g and wont fit on dl disc. I have tried to use ripbot to shrink the original file but there is no sound at all on the preview. and i tried it anyway but it converted without sound like the preview. The i tried to use the finished file from mkv2vob on ripbot but i get this error message: No video sequence header found , then it says: no data check your PIDS. Can anyone help please?
Results 301 to 330 of 341
I am getting this audio filter error when I click on "Preview Script"...
Where can I download this filter? What is it? Anyone familiar with this error? I am using ripbot directly from the m2ts souce file that I pre-ripped to my hard drive.
Thanks.
I spent hours trying to find a fix for this exact problem. After uninstalling Nero 9.0.9.4 the next blu-ray I attempted worked just fine. I haven't yet tested any others. But hopefully if anyone else has this problem, check for a Nero installation and save yourself some time.Originally Posted by sasquatchgeoff
Note: on Vista SP1 when ripbot worked flawlessly I used Nero 7.10 without conflicts. I will likely attempt reinstalling that version to test for conflicts.
I have the same problem:Originally Posted by bdcott
http://img2.abload.de/img/123ftiy.png
but I dont had installed Nero on this PC.
I uses Win7RC 64bit.
Please help.
Geoff, I had this exact problem with Windows 7 release candidate x64 edition.Originally Posted by sasquatchgeoff
I have now solved it by updating all of the accessory programs (avisynth - dec '08, ffdshow x86 & x64 - about 1 week old, Matroska_Splitter - about 1 month old, MKVToolsNix - around March, and Ripbot264 itself - about 2 weeks old).
The newer Ripbot then asked for Java Runtime to be installed (with a link), which I previously had by default in my XP x64 install due to running Open Office. I installed that and haven't had a problem since.
The new GUI with the darker text is better also (thanks Atak_Snajpera)
I also run Nero 8, which has nothing to do with the operation of RipBot264 as far as I can see & fail to see how that could have been a problem!
Cheers
MartyThe problem with designing something completely foolproof, is that designers often underestimate the ingenuity of complete fools!
I am new to rippinbg blu ray. I am trying to use ripbot, but the program seems to hang when it gets to Getinfo.avs. What is get info.avs and should it still be doing what it does 3 hours after it started.
I am trying to run this on a
Dell Quad Core Q6600 with 3 GB RAM. Am I not fast enough?
Please help.
\Thanx
Derelict_Drvr, Assuming you are using AnyDVD for the decryption, try ripping the BD to your hard drive and running RipBot from that file. If you still have problems, open it with tsMuxeR and select the main movie and the desired sound track, then 'start muxing'. Use that for a input to RipBot.
If you still have problems, it may be with the RipBot install. Try uninstalling and reinstalling and check your versions of the required programs for RipBot. One of them may be the problem.
If you are asking about a line similar to this: D:\temp\RipBot264temp\job1\getinfo.avs, line 2) , then ripping to your HDD and using tsMuxeR as above should solve that. It happens on some of my BD>MKV conversions.
And welcome to our forums.
Hi All, was using Ripbot in windows vista ultimate x64bit no problems.
have recently upgraded to windows 7 ultimate x64bit build 7600 due to a pc crash.
have reinstalled ripbot and accessory programs however, after I select the Blu-Ray structure and press ok - whilst loading the content it locks my pc up completely.
all vitals (voltage, temp & cpu/ram usage are well in the green, it's barely doing more then 25% util) but it locks up dead... I re-ran a 24 hour torture test to rule out the overclock and re-attempted a rip - but alas.... no go - again full lockup after loading the blu-ray structure.
Anyone else had any problems?
Cheers,
Matt
Whilst i think ripbot is an amazing tool, and god bless the creator. Theres one thing i want to ask. I used bd builder once to back one of my movies up and it worked great. On the video play back on my ps3 when i fast forward or rewind it worked perfect. But i prefer ripbot but i have noticed i have backed up a lot of my blu ray's using ripbot but the fast forward and rewind are a bit dodgy. has anyone witnessed this. it sort of forwards then stops for a while. Its really laggy.
Thanks for this m8, was looking for something like thatOriginally Posted by Baldrick
This is.....strange. I used Ripbot on my computer and it took a 18GB blu ray movie down to a mear 818MB MKV file! I compared them side by side and the only difference is audio is less quality and the video is a little blurry. This was my first movie conversion and I'm kinda shocked at how small the file was. Did I do something wrong? I followed this exact process
hi
sorry for the question, but i have spiderman 2 bd and there is not one big m2ts file. the movie is split to multiple files with multiple filesize like many mb up to gb.
is there a way to get the correct filelist for the main movie from mpls or is there a program that can automaticly merge the splited movie to one big m2ts?
are there other movies like this, where no one big m2ts file is present?
thanks
Use bdinfo, read http://forum.videohelp.com/topic372380.htmlOriginally Posted by klsc
many thanx
this app looks good. I'll go testing it in the evening
top answer speed
I had an encoder error while trying to encode my first disc, do any of you know what might cause this? It's "x264 [error]: 2nd pass has more frames than 1st pass (149569 vs 113284)". I'm currently trying it again in CQ mode, but i'm still curious why it didn't work in 2pass.
Here is the log:
Code:D:\>"C:\Users\nbayer333\Desktop\ripbot\tools\avs2yuv\pipebuf.exe" "C:\Users\nbayer333\Desktop\ripbot\tools\avs2yuv\avs2yuv.exe" "D:\temp\RipBot264temp\job1\job1.avs" -raw - : "C:\Users\nbayer333\Desktop\ripbot\tools\x264\x264_x64.exe" --pass 1 --bitrate 4351 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 149569 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264" - 1920x1080 : 2 x264 [info]: 1920x1080 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (25000) > level limit (20000) x264 [info]: using cpu capabilities: MMX2 SSE2Slow x264 [info]: profile Main, level 4.0 D:\temp\RipBot264temp\job1\job1.avs: 1920x818, 10000000/417083 fps, 149569 frames x264 [info]: frame I:8683 Avg QP:40.07 size: 22385 x264 [info]: frame P:104599 Avg QP:42.57 size: 24105 x264 [info]: frame B:2 Avg QP:32.64 size: 28110 x264 [info]: consecutive B-frames: 100.0% 0.0% 0.0% 0.0% x264 [info]: mb I I16..4: 97.4% 0.0% 2.6% x264 [info]: mb P I16..4: 97.1% 0.0% 0.0% P16..4: 2.8% 0.0% 0.0% 0.0% 0.0% skip: 0.1% x264 [info]: mb B I16..4: 34.9% 0.0% 0.0% B16..8: 63.9% 0.0% 0.0% direct: 1.2% skip: 0.0% L0:48.9% L1:51.1% BI: 0.0% x264 [info]: final ratefactor: 38.52 x264 [info]: direct mvs spatial:0.0% temporal:100.0% x264 [info]: coded y,uvDC,uvAC intra:2.8% 56.9% 41.6% inter:17.9% 97.6% 66.8% x264 [info]: kb/s:4598.2 encoded 113284 frames, 10.80 fps, 4598.85 kb/s D:\>"C:\Users\nbayer333\Desktop\ripbot\tools\avs2yuv\pipebuf.exe" "C:\Users\nbayer333\Desktop\ripbot\tools\avs2yuv\avs2yuv.exe" "D:\temp\RipBot264temp\job1\job1.avs" -raw - : "C:\Users\nbayer333\Desktop\ripbot\tools\x264\x264_x64.exe" --pass 2 --bitrate 4351 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 149569 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264" - 1920x1080 : 2 x264 [info]: 1920x1080 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Slow x264 [error]: 2nd pass has more frames than 1st pass (149569 vs 113284) x264 [error]: x264_encoder_open failed D:\temp\RipBot264temp\job1\job1.avs: 1920x818, 10000000/417083 fps, 149569 frames Output error: wrote only 1787341 of 2355840 bytes D:\>"C:\Users\nbayer333\Desktop\ripbot\tools\mkvtoolnix\mkvmerge.exe" -o "D:\encoded\transporter.mkv" --title "transporter" --default-duration 0:24000/1001fps -d 0 -A -S "D:\temp\RipBot264temp\video.264" --language 0:und --sync 0:0 -a 0 -D -S "D:\temp\RipBot264temp\job1\audio.1.core.dts" --chapters "D:\temp\RipBot264temp\job1\chapters.txt" mkvmerge v2.9.0 ('Moanin'') built on May 22 2009 17:46:23 Error: The file 'D:\temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus
if your file type is supported but not recognized properly. ------------------------- Elapsed Time: 02h:54m:55s
I am trying to run ripbot264 and getting the followin error after is has completed a couple of percent progress, the x264_x86 seems to continue to grab memory and then fail. The first bit of the mkv file works perfectly but of cource i only get a couple of minutes.
I have run a full memory test which did not show up any errors
Thanks in advance for any suggestions as to what I can do to fix this
The error:
x264_x86 has stopped working
System:
centrino 2, os vista home premium with 4gb RAM
event viewer logs:
Log Name: Application
Source: Application Error
Date: 12/10/2009 10:02:08
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: laptop
Description:
Faulting application x264_x86.exe, version 0.0.0.0, time stamp 0x4aa75e14, faulting module msvcrt.dll, version 7.0.6002.18005, time stamp 0x49e0379e, exception code 0x40000015, fault offset 0x000641b5, process id 0x161c, application start time 0x01ca4b1a65b38e84.
Event Xml:
1000
2
100
0x80000000000000
8706
Application
laptop
x264_x86.exe
0.0.0.0
4aa75e14
msvcrt.dll
7.0.6002.18005
49e0379e
40000015
000641b5
161c
01ca4b1a65b38e84
did you find the solution to this problem? I'm asking because it's happening to me, after demuxing the streams windows media player classic opens and giving a message "opening file....Originally Posted by parafun
that happens to me by covnerting VC-1 video sources.media player classic opens and giving a message "opening file....
i got a solution but after installing the final Win7 i have the same arror again and don't know how i solved it in the moment
Hi! I am a newbee to this forum! I have been reading this nice guide from Baldrick on how to convert Bluray to MP4 HD or MKV HD. Since I can see this guide is quite old (Oct 18, 2008), the question is now: Is that still the best way to do the job?? Or there is another better, easier, or more efficient way? If yes, could you please let me know and also tell me if there is any new guide for the conversion from Bluray to MP4 HD or MKV HD ???
Thanks!
use ripbot newest version with CQ18 for best output quality or CQ20 is also good but much smaller filesize. you can also reduce 1080p to 720p. good luck
Hi! Thank you for your reply to my question. The guide on the 1st page of this topic is using RipBot264. So, do I finally still follow this same old guide to do the job?Originally Posted by elJorda
i think nothing changed here. only the internal software was updated.
hey guys i am confused on a certain step
Intel Core 2 Quad Q9000 2.GHz
4.00Gb Ram
Vista 64-Bit
I used the tsmuxer and got the .ts file
opened ripboot264, i click on "add"
then i click on the "..." next to video
then it starts demuxing the stream
then for some reason it dont let me choose any of settings like the "profile" or whether to save it as mp4 or mkv
what pops up is media player classic then an error message pops up saying this (image)
can anyone help me with this problem i would well appreciate any type of help
Anyone knows about the fast forwarding issues on mkv?
No FF useable on RipBot files.
In what program are you trying to FF, WMC?Originally Posted by longtomCheers,
Damian
blog - http://dbone1026.blogspot.com
contributing editor - http://www.mediasmartserver.net
It's in Western Digital TV HD Media Player.Originally Posted by dbone1
Cheers,
Damian
longtom, I don't have any problems FF'ing my RipBot MKVs with my WD Live2 over my LAN from the server.
medina06, try reinstalling AVISynth. It sounds like the RB program can't find it.
joy, you might try a different version of RipBot. Also uninstall all the auxillary programs then re-install them all. It may be a problem with the parts of the program not being able to connect, or parts of the program or the video files on on different drives and RipBot isn't finding them all. Ripbot also generates a log and you might find more information there.
so what would be an average file size of a 2 hour movie using cq18 with 1080 and cq20 with 1080Originally Posted by Kostas75
Hello. i had to install ffdshow 32 bit to run ripbot even tho im using win 7 64 and already have ffdshow 64 on my comp and i get this error
directShowSource: couldn't open file H:\temp\RipBot264temp\job1\video.mkv:
The system cannot find the file specified.
I tried opening ffdshow to change the vc-1 settings but its not even listed. in the 32 bit version anyways...
Convert VC-1 Encoded Blu-ray Rip .m2ts to .mp4 in 32-bit Windows 7
By luigi2000 in forum Blu-ray RippingReplies: 10Last Post: 21st Jan 2010, 15:50 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 36Last Post: 21st Jan 2010, 03:18 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 17:50 -
Convert .MKV to .MTS (AVCHD) for use in BD 35 Blu Ray player
By NirvClub in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2009, 15:51 -
Problems with Blu-ray to MP4 HD
By zenzen1 in forum Blu-ray RippingReplies: 9Last Post: 11th Dec 2008, 09:30
Newest guidesLatest tool updatesNew media commentsRecent DVD HacksReplay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
