Results 1 to 11 of 11
    hi . i have a lot of mkv movies OK . But the problem is Avery time i download subtitle
    There is a difference between the timing between sound and the the text .
    Tried with many program to Edit the subtitle But the problem all the program Does not accept
    MKV . WHAT IS THE BEST PROGRAM CAN FIX THIS ?
    THANKS
    What format for subs? .srt?
    You can extract them from the .mkv container with mkvextractgui (from the mkvtoolnix kit)
    You can edit subs with subtitle workshop
    Then you can repackage your .mkv with mkvmergegui
    Sometimes subs have different versions (e.g. extended uncut version of a movie, or PAL vs. NTSC version....etc.. so you have to use the correct one)
    the format is srt . Tried with subtitle workshop But its Crash Avery time i lode mkv file .
  4. Member t0nee1's Avatar
    Did you extract the .SRT file from your mkv? The .srt is the file you open with subtitle workshop..You don't load the mkv...
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
    NO the srt file not inside the mkv . I Download the srt file from some site for subtitle . the problem the difference between the timing between sound and the the text . In the past it was easy to fix this with avi file if i use SubtitleEdit program . But SubtitleEdit do not support mkv . I Tried with subtitle workshop But its Crash Avery time i lode mkv file .
    I have to lode mkv file so that i can fix the ifference between the timing between sound and the the text .
    I see that no one had the answer to it ?
    I am having same problem.
    I want to create some Subtitles for some videos, the videos are in mkv. But No software i found can open MKV file. How can i create sync subtitles if i cant open the video file.
    Please anyoen can help ?
    thanks a lot in advance
    I am using the old version of Subtitle Workshop version 2.51
    I can load separate srt file associated to mkv file, them Subtitle Workshop version 2.51 loads mkv file automatically. I can edit the subtitle file. It worth say that in this case Subtitle Workshop version 2.51 does not work smoothly and may crash many time, but it works. Anyhow it crashes with avi files also. I found that the crash is very much related to the installed codec package.
    New version of Subtitle Workshop are not the same as old version, there are many functions removed from new versions.
    When ever you download a srt subtitle then your first step is to check the frame rate of both the srt and the movie.
    srt frame rate can be checked from the site which you downloaded it from. The uploader usually provides you with the necessary information (Number of cds, frame rate .. etc)
    also as said above you have the check the srt version against the movie version .. there are many versions like unrated, director cut, remastered, extended edition and so ..
    if both the srt and the movie have the same frame rate then you can use subtitle workshop to adjust the time (adjust the time delay forward or backward)
    if they have a different frame rate (23.976, 24, 25..etc) then you MUST first convert the srt frame rate to the correct frame rate which is in this case the movie's frame rate. Then you can use subtitle workshop again to adjust the time as above.
    usually if the source is PAL then the frame rate is 25 and for NTSC is 23.976 but there is always exceptions.
    a good utility to do all these conversion and time adjusting is Subtitle creator. It accepts srt, idx/sub and SUP format.
    I hope this is useful for you.
  9. if you download an srt off the internet to go your movie, you can use time adjuster to tweak the timings. just google it. it's a great freeware program for that kind of stuff.
    once you tweak the srt file, just use mkvmerge to put it into the mkv container.
  10. I've had the best luck with Subtitle Workshop v. 4
    Play the video to get a good idea when the first and last subtitle should be displayed.
    Load the .srt in Subtitle Workshop 4. Hit Control B hotkey(^b) to bring up subtitle timing
    dialog box. Enter the time the first and last sub should be displayed. Unless the .srt is
    for a different cut of the film you should be able to get it close enough to watch without
    being distracted. You should be able to get the first sub correct on the first go. You may
    want to adjust the last sub timing a few times until you get it exactly. The rest of the subs
    should line up with the audio then.
    http://www.FavesSoft.com
    "I don't want to belong to any club that would have me as a member."
    - Groucho Marx
  11. No way I could figure out how to pause the movie in this new version. Please help.
    Edit:
    Oops, that was stupid. Just click on the movie preview
  1. How to attach subtitle to .mkv
    By KoRatta in forum Subtitle
    Last Post: 22nd Jan 2012, 09:50
  2. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 1st Dec 2011, 06:10
  3. HandBrake No Subtitle in MKV
    By kinghlg in forum Subtitle
    Last Post: 16th Dec 2009, 21:07
  4. MKV Subtitle
    By solosoul in forum Subtitle
    Last Post: 19th Mar 2009, 01:30
  5. MKV > H.264 but no subtitle...
    By flying in forum Newbie / General discussions
    Last Post: 8th Jan 2006, 12:08
About   Advertise   Forum   RSS Feeds   Statistics   Tools
