HI
as the topic states I have a laptop and the only out is VGA. on my TV I ave scart, s video, rgb in.
I tried to get my laptop on my pc by using a VGA to TV Converter S-Video & RCA Out Cable Adapter (4 Converter)
then RCA cable from that to my TV. This did not work. I also tried putting the RCA into a scart convertor into the scart on my tv but no luck.
I was thinking about using vga to s video then s video cable into my tv but read that s video quality is pretty poor.
I have the sound from my laptop into my tv using a 3.5mm Jack to 2x RCA Phono Cable.that was so simple, if only all things could be!
I know my laptop can work on a tv as my sisters tv has vga in, and a simple vga cable works just fine getting the image from my laptop to her tv.
anyone any suggestions what I need?
Theres alot of confusing information around about types of signal horizontal, vertical etc I dont really need to dig too deep into all that.
This is this from maplin but is expensive
http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15
please help! =[
** UPDATE **
Ive come across this item
StarTech.com VGA/HD with Audio to HDMI Format Converter - video converter for £88
http://www.it247.com/Product/774-VGA...843113&whence=
think this will produce hassle free quality results? price seems fair
and here is a detailed list of the inputs on my tv:
2 x HDMI ( 19 pin HDMI Type A ) - rear
1 x SCART (AV in/out / S-Video) ( 21 PIN SCART ) - rear
1 x SCART (AV in/out / RGB) ( 21 PIN SCART ) - rear
1 x audio line-in ( RCA phono x 2 ) - rear
1 x component video input ( RCA phono x 3 ) - rear
1 x headphones ( mini-phone stereo 3.5 mm ) - side
1 x S-Video input ( 4 PIN mini-DIN ) - side
1 x composite video/audio input ( RCA phono x 3 ) - side
