VideoHelp.com Forum
    Hi,
    When I open DVD shrink and attempt to "re-author" the file, DVDshrink shuts down. I unistalled DVDshrink, re-booted
    the computer and re-installed the program. I even downloaded another copy of DVDshrink thinking that the installation file had been corrupted. I still get
    the same problem. I like to edit the file to reduce the compression. Suggestions?
    Sincerely,
    GF
    Is the source file you are reauthoring stored on your harddrive, or is DVDShrink reading from a disc in your DVD drive? Is the DVD copy protected?
  3. Member dialysis1a's Avatar
    Do you by chance have IE8 installed?
    I do have IE8 installed.
    I copied the DVD to the HD with Ripit4me and then attempted to re-author the DVD file. I can back up the file thereby reducing the file size to fit on a single sided DVD but I want to get rid of the credits at the end.
  5. Member dialysis1a's Avatar
    Go back to IE7. This is a known problem with IE8.
    Thank you, I'll try that.
    It worked, thank you for your help and advice!!
  1. My mouse stops working randomly
    By sohaibrazzaq in forum Computer
    Last Post: 17th Mar 2012, 17:30
  2. AVStoDVD stops working after encoding video
    By tperkins13 in forum Authoring (DVD)
    Last Post: 19th Apr 2011, 07:10
  3. ffmpeg stops working in VOB2DVD
    By DrDigital in forum SVCD2DVD & VOB2MPG
    Last Post: 9th Nov 2009, 20:14
  4. Optical device stops working
    By Crazewolf in forum DVD Ripping
    Last Post: 10th Jun 2009, 05:20
  5. itunes stops working
    By angelatony in forum SVCD2DVD & VOB2MPG
    Last Post: 17th Sep 2007, 10:44
