Hi,
Im trying to get video from a DVD into Adobe Premiere Pro so I can edit it. Ive converted the DVD to vob using DVDFab and have tried converting it into AVI format using Avidemux. However, I cannot get Premiere to import it properly. It imports the video fine but the audio is never imported even though it is present when I play the avi in VLC media player and WMP.
Is there anyway to get this working? Perhaps a codec or plug-in to download?
Thanks in advance.
Hmmm...when I try to import the PCM audio only file Premiere says "file format not supported"
Check to ensure the wav file's sampling rate is 48000Hz with 16-bit, 2-channel stereo. I don't know which version of Premiere you have, but it may not like the makeup of the audio file.
Importing MPEG-2 videos on Premiere Pro on OS X Lion
By Atoon in forum MacReplies: 1Last Post: 1st Feb 2012, 04:08 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 02:56 -
Importing AC3 into Premiere Pro ?
By Zetti in forum EditingReplies: 14Last Post: 23rd Jan 2009, 01:45 -
UNresponsive premiere pro when importing big wmv
By hanugro in forum Video ConversionReplies: 4Last Post: 30th Dec 2007, 21:26
