VideoHelp.com Forum
    I am trying to convert a .TS file that I captured to h264 mp4 playable in quicktime. I want to do this with as minimal quality loss as possible. I have tried using automkv and the video comes out great, but for the life of me I can not get any audio output. I have tried choosing all audio tracks option and both original codec and nero and still no audio. I have managed to us tsmuxer and saved the audio as aac which plays fine in quicktime but even if I use this as my audio file im automkv there is still no audio output. Am I doing something wrong or is there a better app that someone can recommend that I should be using for this conversion? Here are the details of an example ts file. I got this info with mediainfo.
    General
    Complete name : M:\2008_10_8_17_50_11.TS
    Format : MPEG-TS
    File size : 14.0 MiB
    Duration : 14s 691ms
    Overall bit rate : 7 985 Kbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Main@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Duration : 14s 683ms
    Bit rate : 7 536 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 16/9
    Frame rate : 59.940 fps
    Standard : NTSC
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Audio
    Menu ID : 1 (0x1)
    Format : AAC
    Format version : Version 2
    Format profile : LC
    Muxing mode : ADTS
    Bit rate mode : Constant
    Bit rate : 132.3 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Video delay : -50ms
    Your audio should already be compliant for QT in Windows, so you shouldn't have to re-encode that.
    Your video might be compliant, if not, then you have to re-encode that using a QT compatible profile. (AVC Main, No I8x8, no mixed reference frames, no B-pyramids, max 1B-frame). Ripbot264 and MeGUI have preset profiles that make it easier.
    If the video is already compliant, just "switch the containers" using MP4box (YAMB is the GUI), or MP4muxer. MP4muxer is better than MP4box for QT compatible MP4 muxing.
    DGAVCIndex demux with it open the dga file in megui then convert audio in winamp then add audio in megui
  1. Replies: 33
    Last Post: 16th Apr 2012, 02:47
  2. Is AVCHD Still Difficult to Edit?
    By HoosierGuy in forum Editing
    Last Post: 21st Nov 2011, 22:11
  3. Win32 FFMpeg Makes Invalid MP4 ?
    By Endemoniada in forum Video Conversion
    Last Post: 22nd Sep 2010, 09:32
  4. Need help with very difficult MPEG-2 conversion/generation
    By likecheese in forum Video Conversion
    Last Post: 13th Nov 2008, 22:38
  5. Video to PSP. Does it have to be this difficult?
    By Colmino in forum Video Conversion
    Last Post: 5th Jun 2008, 00:38
