Hi,
I have some FLV files that have h.264 video and aac audio inside (Hulu 480p). What I want to do is remux that into a different container (mp4 would be nice but i'm fine with avi) without re-encoding since it is already in h.264. I downloaded ffmpeg (r15562) from http://www.razorbyte.com.au/ffmpeg/ and this is the version of xvid I installed (ffmpeg complained about not having a xvid dll) http://www.divx-digest.com/software/xvid.html
I also have ffdshow tryouts (latest) installed with it set to decode h.264
So, when I try using ffmpeg, at the command prompt (XP SP3), I am typing in (where m2.flv is the original):
ffmpeg -i m2.flv -vcodec copy -acodec copy m2.mp4
FFmpeg does convert the file but it continually repeats [mp4 @ 0xe28070]pts has no value... Looking back, it sometimes gives a line of information about bitrate, but the rest of the lines are that same message. At the end, it says frame=22200 fps=890 q=-1.0 117002kB time=984.02 bitrate=974.0kbits/s video:105574kB audio: 10567kB global headers: 0kB muxing overhead 0.741513%. When I try to play back the file, the audio only plays for a few seconds until becoming silent and the video is so choppy/stuttery that is it unwatchable.
I am open for any ideas (even using entirely different programs)
Thanks!
Kurt
Edit: forgot to mention what libraries were built in my ffmpeg:
Included libraries:
FAAC 1.26
FAAD2 2.6.1
gsm 1.0.12
LAME 3.98.2
liba52 0.7.4
liboil 0.3.15
libtheora 1.0beta3
Ogg 1.1.3
SDL 1.2.13
Shroedinger 1.0.5
x264 r999
Xvid 1.2.0-dev (CVS HEAD 2007-07-26)
Vorbis 1.2.0
When I try to open the flv inside of avidemux it says "No audio decoder found for this file. Save (A+V) will generate bad AVI. Save audio will work." It then opens it up, however, the only thing it displays in the preview window is a green frame. I first tried to make an mp4 using video copy and audio copy. It then said "Invalid audio stream detected. The audio stream may be invalid for this container. Continue anyway?". If I click on continue, it says "Failed".
I then tried to demux the flv. Inside of avidemux I went to audio, then clicked on save and saved it with an aac extension. I then disabled the audio track and exported the video as an mp4. I didn't see any other way for me to just extract the video (maybe I'm missing something). YAMB refused to mux the aac and the video I saved. I have a feeling that I didn't do this step correctly because the video was in an mp4 container.
Any advice?
Thanks!!
Alright guys... I got it working!
For anybody that wants to remux Hulu 480p:
Check out this thread I found: (scroll down to the post by BlueCop): http://forum.doom9.org/showthread.php?t=141120
If you set things up the way I did the first post of this thread and follow BlueCop, it should work perfectly.
The only thing that can be different is finding the frame rate of the 480p video. Since many players can't figure out the frame rate of the 480p flv but can of a normal flv, simply rip the low quality stream and the high quality stream. Since the frame rate of the low quality stream and the high quality stream is the same, just use any other program to find the frame rate. Also, in the original file name (when replay is still ripping), it will usually tell you the frame rate.
Here are the ones that I have had to use so far:
23.976 FPS
29.970 (it says 30FPS on the file when ripping)
Good Luck!!
What is the exact command line you have used to remux using MP4box? Here is what I have used but it seems to be ignoring the FPS line.
MP4Box -add output_track1.h264 -fps 23.976 -add output_track2.aac New.mp4
Rick
Rick:
Here is exactly what I am using:
mp4box -add hulu_track1.h264:fps=23.976 -add hulu_track2.aac final.mp4
Good luck!
-Kurt
For anyone who cares here is a quick batch script to convert from FLV to MP4.
The format is
mp4encode.bat <inputfile> <fps> <outputfile>
RickCode:@echo off if "%1"=="" goto use if "%2"=="" goto use if "%3"=="" goto use ffmpeg -i %1 -vcodec copy -acodec copy OUTPUT.mp4 mp4box -raw 1 OUTPUT.mp4 mp4box -raw 2 OUTPUT.mp4 del output.mp4 mp4box -add output_track1.h264:fps=%2 -add output_track2.aac %3 del output_track1.h264 del output_track2.aac goto end :use echo. echo USAGE: echo %0 [inputFile.flv] [fps:29.97:23.976] [outputFile.mp4] echo. :end
Thanks for the batch file Rick!
I had my own set of batch files to do the same thing, but yours is much more elegant and will save me some time.
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 52Last Post: 16th Jan 2010, 02:08 -
HD 720p H.264 MP4 video ?????
By RunAway in forum Newbie / General discussionsReplies: 9Last Post: 24th Dec 2009, 20:42 -
Remux H.264 Transport Stream as .mp4 (or other)
By Maddux in forum MacReplies: 7Last Post: 2nd Jun 2008, 14:41 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25 -
MP4 H.264 No video, only audio
By mjoeyoung in forum ffmpegX general discussionReplies: 1Last Post: 19th Oct 2005, 04:17
Newest guidesLatest tool updatesNew media commentsReplay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
