VideoHelp.com Forum
    Hi!
    I got the VLC player, but I am experiencing problem with video and audio signal. Mostly with stream videos or stream TV-s, where is not audio or video. Why? Any help? Thanks a
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I haven't seen any problems with VLC and Vista, but you might check what audio output VLC is using. Vista handles audio differently than XP, so you may have to make some adjustments. My audio outputs through S/PDIF, so it requires different settings.
    I don't use streaming that much, so not much help there. Do you have a specific example of a streaming problem, such as a link to a site that doesn't work? And you might also take a look at this post by Baldrick: http://forum.videohelp.com/topic316907.html
    Thanks my friend.
    I am having the same problem with any video or audio streaming which need to be played by VLC player. For example if I try cool streaming channels, any of them has the same problem, no video or audio at all
  4. contrarian rallynavvie's Avatar
    Is it the 64-bit version of Vista?
    FB-DIMM are the real cause of global warming
    No. 32 bit
  1. how to streaming with VLC v1.1.4 on vista
    By pRincezZ_fe in forum Video Streaming
    Last Post: 16th Dec 2010, 01:16
  2. Problems Using Snipping Tool (Windows Vista) with Blue Ray Discs
    By rib in forum Newbie / General discussions
    Last Post: 16th Feb 2010, 04:02
  3. try to ge VLC work with Vista ultimate
    By volam in forum Software Playing
    Last Post: 19th Jun 2009, 00:19
  4. VLC on Vista Business
    By niku7 in forum Software Playing
    Last Post: 3rd Jan 2008, 08:14
  5. Replies: 6
    Last Post: 12th Nov 2007, 10:25
