VideoHelp.com Forum
    I want to purchase Taiyo Yuden media with the code YUDEN000 T02. According to a poll at http://club.cdfreaks.com/f33/cdfreak...acodes-247164/ and a number of other sources these are some of the best media you can buy. I also know you have to watch out for fakes.
    On www.meritline.com they have Taiyo Yuden media with the code YUDEN00T02. Notice the code YUDEN00T02 only has only two 0's after the YUDEN and before the T02.
    Below is from http://www.meritline.com/taiyo-yuden...r-thermal.html
    Authentic Taiyo Yuden DVD+R media, made to the highest standards. Highest quality, suitable for duplication and public distribution. Features archival quality AZO metal dye for today's longest archival playback capabilities. Should last up to 100 years or longer in normal cool dark storage conditions.
    Additional INKJET or THERMAL (as specified in product title above) printable surface has been added over Taiyo Yuden's high reflectivity layer. Compatible with Rimage Prism, Primera Inscripta and other leading thermal transfer CD/DVD disc printers (not recommened for Everest printers). These discs are also suitable for screen printing. Disc features no stacking ring -- this means it can be printed by today's high speed disc production systems.
    Manufacturer: Taiyo Yuden
    Manufacturer Part#: DVD+R47ZZSB8 (Made in Japan)
    Media Code: YUDEN00T02
    Media Type: DVD+R, DVD Plus R Blank Media
    Storage Capacity: 4.7GB
    Recording Speed: 1X - 8X
    Top Surface: Silver Thermal Lacquer
    No Stacking Ring
    Most sources suggest there is supposed to be three 0's. Does the variation between two or three 0's in the Taiyo Yuden media code make a difference or are they the exact same media?
  2. Member FulciLives's Avatar
    I only buy Taiyo Yuden from RIMA.COM and I only buy DVD-R as I am philosophically opposed to DVD+R discs.
    My main point though is this: you won't be getting fake Taiyo Yuden from RIMA.COM
    - John "FulciLives" Coleman
    P.S.
    The last batch I bought from RIMA.COM are the Taiyo Yuden 8x DVD-R discs with the "Silver Lacquer (Shiny Silver)" surface. The code reads: TYG02
    I'm sure its just a typo. The actual code is YUDEN000T02 and there's actually a space in there somewhere too. The media ID software can vary a tad too.
  1. Difference matte?
    By Abiyad in forum Mac
    Last Post: 22nd May 2008, 15:38
  2. What's the difference between these two products?
    By Waterkips in forum Capturing
    Last Post: 21st Apr 2008, 00:40
  3. what is difference to + and - DVD-R and RW?
    By snadge in forum DVD Ripping
    Last Post: 27th Feb 2008, 12:14
  4. Replies: 2
    Last Post: 3rd Jan 2008, 19:42
  5. Can YOU Tell the Difference ?
    By Seeker47 in forum DVB / HDTV
    Last Post: 19th Nov 2007, 12:59
