Hi
i am using the free trial to see how it is befor i buy it. when ever i open it i get this the application has failed to start because pthreadGC2.dll was not found reinstalling the application may fix this problem. i did it with no luck can anyone please tell me how to fixes this?
thank you i have vista home premium 32bit
Thread: avs video converter 6 help
Can I suggest that if you really must try this POS (piece of software) then you contact their support people of do a google search for the missing dll.
Personally, I wouldn't touch it. Like most of the commercial budget-end converters, AVS is low quality, unreliable and not worth the money. There are far better freeware tools available. They may not look as pretty, but it is the look of the output, not the look of the application, that counts.
Hi guns1inger
do you know of any better ones?
thank you
What are you trying to convert (from and to) ?
Xvid4PSP is a high quality converter that will convert many formats to to most standard formats. It comes with a comprehensive set of templates for most devices, from the Nintendo DS through to the PS3, Apple TV etc, as well as MKV and other formats. Very highly recommended.
SUPER covers a wider range from of formats, however the quality is probably not as good in most cases.
AVS Video Converter - No audio
By Djard in forum Video ConversionReplies: 1Last Post: 21st Jul 2011, 15:49 -
AVS Video Converter
By Huh...What? in forum Video ConversionReplies: 3Last Post: 31st Jul 2010, 09:55 -
AVS video converter
By jakewoodblues in forum Video ConversionReplies: 1Last Post: 20th Oct 2009, 15:41 -
AVS Video Converter vs ConvertxtoDVD
By kuerenz in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 10:44 -
avs video converter
By ocko in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2008, 17:33
Statistics
Newest guides
Latest tool updates
New media comments
