I have some h.264 clips shot on my DXG HD camera that I'd just like to trim, losslessly and quick. Is there a tool that can do that?
Thread: Lossless h.264 or avchd cutter
Not very easily. h264ts_cutter may work on some types of streams, but only on I-frames and is a bit buggy
I would suggest checking the software that came with the camera. It might not be the best or most user friendly software but it should be compatible.
At the very least its a place to start. Usually they have some kind of "se" or "limited" or "light" edition of a commecially available editing package. That it in itself is a good test run to see if you would be better off getting the "full" version of that said package.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
AVCHD MTS Cutter
By cheerful in forum EditingReplies: 11Last Post: 25th Jan 2010, 20:58 -
h.264 ts cutter
By stewart041170 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2010, 15:06 -
Looking for software to use as an AVCHD frame cutter
By sebaz in forum EditingReplies: 2Last Post: 19th Sep 2009, 14:29 -
error message with H.264 TS cutter
By chiro14 in forum EditingReplies: 0Last Post: 1st May 2009, 14:49
Statistics
Newest guides
Latest tool updates
New media comments
