Hi everyone,
Just joined because I just purchased a LG RH387H HDD Recorder.
I know that this player has an upscale function, but I can't seem to find it when I play a DVD disc movie. I figure it should automatically upscale it to 1080, but it's stuck at 576p on my TV. My TV is full 1080p, so i know the TV can handle it. If anyone can help me with this I'd great appreciate it.
Thanks!
To use the up converting function it has to be connected to your tv with an HDMI cable or a componant cable. Then just push the RES button until you get the resolution you want.
You need to use the HDMI connection to get upconversion.
i have it connected through HDMI, but there's no res button at all anywhere. the HDMI cable i have is 1.3 too.
i figure you can upscale manually. anyone have any ideas?
thanks!
If your TV is really full 1080p then it will upscale any video signal it gets at a lower resolution to 1080p. In fact your TV might actually upscale better than your LG recorder. I would not worry about it. I have an old Philips DVD player that can't output anything above 480p, so I just let my Samsung HDTV upscale for me and it looks great.
By the way, have you not looked in the manual for instructions on how to upscale? Again, note that your TV may actually do a better job than this player on upscaling.
Somewhere in the menus on the LG there will be resolution settings if there isn't a key on the remote. Like jman said, if you've got a good TV it will probably do a better job of upconverting than the LG.
The "res" button is on the panel of the recorder, but not the remote.
Rh387h
By Train45 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 25th Feb 2011, 16:36 -
LG RH387H Dubbing from HHD to DVD-R
By SB4 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th Sep 2010, 19:56 -
LG RH387H Region Free
By ctoffa in forum Newbie / General discussionsReplies: 0Last Post: 24th Jun 2010, 07:10 -
netbook upscale dvd?
By ieh4f in forum Software PlayingReplies: 2Last Post: 29th Mar 2010, 19:01 -
Record from TV using LG RH387H. How ?
By SB4 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Mar 2010, 07:28
