VideoHelp.com Forum
Thread: AAC in MENCODER
    Hello.
    I installed and compiled mplayer with memcoder from here-> http://debian-multimedia.org/pool/ma...06.orig.tar.gz
    I tried to encode vob to mp4 (for PSP)
    found this command line in some tutorial:
    ./mencoder test.vob -oac lavc -ovc lavc -of lavf -lavcopts aglobal=1:vglobal=1:vcodec=mpeg4:acodec=aac -af lavcresample=24000 -vf harddup -lavfopts format=psp -ofps 30000/1001 -vf scale=320:240 -o test.mp4
    but it gave me following error:
    MEncoder dev-SVN-rUNKNOWN-4.1.2 (C) 2000-2008 MPlayer Team
    CPU: Intel(R) Xeon(R) CPU           X5355  @ 2.66GHz (Family: 6, Model: 15, Stepping: 7)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    success: format: 0  data: 0x0 - 0xc69f800
    MPEG-PS file format detected.
    VIDEO:  MPEG2  720x576  (aspect 2)  25.000 fps  6000.0 kbps (750.0 kbyte/s)
    [V] filefmt:2  fourcc:0x10000002  size:720x576  fps:25.000  ftime:=0.0400
    Opening audio decoder: [dvdpcm] Uncompressed DVD/VOB LPCM audio decoder
    AUDIO: 48000 Hz, 2 ch, s16be, 1536.0 kbit/100.00% (ratio: 192000->192000)
    Selected audio codec: [dvdpcm] afm: dvdpcm (Uncompressed DVD/VOB LPCM)
    ** MUXER_LAVF *****************************************************************
    REMEMBER: MEncoder's libavformat muxing is presently broken and can generate
    INCORRECT files in the presence of B-frames. Moreover, due to bugs MPlayer
    will play these INCORRECT files as if nothing were wrong!
    OK, exit.
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=320 h=240]
    Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
    VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES)
    The selected video_out device is incompatible with this codec.
    Try appending the scale filter to your filter list,
    e.g. -vf spp,scale instead of -vf spp.
    VDecoder init failed :(
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffmpeg2] vfm: ffmpeg (FFmpeg MPEG-2)
    Audio LAVC, couldn't find encoder for codec aac.
    I know i need to install/recompile mplayer+memcoder with aac libs, but how? where do i find it and how to do it?
  2. Use libfaac instead aac.
    And why not try libx264 instead mpeg4?
    ok i got libfaac but don't know how to add it to mencoder.
    tried adding "libfaac" folder to mplayer directory tree but without any result.
    here's my mplayer dir
    and here are the contents of libfaac dir (dunno if i copied good files)
    i ain't got root access on this server so i had to compile it with --prefix=/tmp/mplayer command
    please tell me how to add libfaac to mencoder, i think adding any other codec will be similar.
  1. MKV AAC GUI Converter with Nero AAC Codec
    By prijatelj.v in forum Audio
    Last Post: 26th Mar 2012, 08:41
  2. Mencoder not copying aac to mp4
    By rzippert in forum Video Conversion
    Last Post: 8th Feb 2012, 18:17
  3. AAC 5.1 to AAC 2ch conversion problem
    By MR 3 in forum Audio
    Last Post: 2nd Feb 2010, 22:44
  4. Replies: 5
    Last Post: 28th Dec 2009, 16:58
  5. Replies: 2
    Last Post: 5th Nov 2009, 01:41
